Project UTM point to DD
4568
11
02-27-2018 08:15 AM
BrianBulla
Honored Contributor
I'm trying to emulate the screen cap below into some JS.
In the SDK for Project there is no parameter specified for the Input Spatial Reference like there in the above screen cap of the Geometry Service I am using, so I'm not quite sure how I specify that in my JS.  Here is what I have so far:
view.on("click", function (event) {
              event.stopPropagation(); // overwrite default click-for-popup behavior
              // Get the coordinates of the click on the view
              var northing = event.mapPoint.y;
              var easting = event.mapPoint.x;
              var geomSer = new GeometryService("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
              var params = new ProjectParameters();
              params.geometries = [event];
              params.outSpatialReference = 4326;
              var newPoint = geomSer.project(params);
              view.popup.open({
                  // Set the popup's title to the coordinates of the location
                  title: "Latitiude: " + newPoint.y + ", Longitude: " + newPoint.x,
                  content:  "Northing: " + northing + ", Easting: " + easting,
                  location: event.mapPoint // Set the location of the popup to the clicked location
Any guidance is appreciated.
BrianBulla
Honored Contributor
OK.  That seems to be working.  At least I am past all of the errors now.  Still not getting the expected result, but at least I am closer.  See below for final code and what I am seeing.  Not sure why the Lat/Long is 'undefined'.
              var geomSer = new GeometryService("https://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/Geometry/GeometryServer");
              params.geometries = [event.mapPoint];
              var id = new SpatialReference();
              id.wkid = 4326;
              params.outSpatialReference = id;
              geomSer.project(params).then(function(projectedPoint){
                  view.popup.open({
                       //Set the popup's title to the coordinates of the location
                      title: "Latitude: " + projectedPoint.y + ", Longitude: " + projectedPoint.x,
              }, function(error) {
                  console.error(error)
BrianBulla
Honored Contributor
Yes!!  I finally got it:
title: "Latitude: " + projectedPoint[0].x + ", Longitude: " + projectedPoint[0].y,
Wow....that was a lot of work.
