Project Geocode Results
1143
06-01-2010 01:28 PM
RichardBailey
When using the "Geocode an Address" sample from the 1.6 version of the JavaScript API, I would like to use the ESRI_Geocode_USA locator as listed but show results on a local map service that has a different spatial reference. Can anyone assist with the best approach?
Thanks in advance.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/>
    <meta http-equiv="X-UA-Compatible" content="IE=7" />
    <title>Find Address</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/1.6/js/dojo/dijit/themes/tundra/tundra.css">
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=1.6"></script>
    <script type="text/javascript">
      dojo.require("esri.map");
      dojo.require("esri.tasks.locator");
      var map, locator;
      function init() {
        map = new esri.Map("map", { extent: new esri.geometry.Extent(1490176.82038304,648636.119034206,1493286.59857839,651174.565886689, new esri.SpatialReference({ wkid: 3735})) });
        dojo.connect(map, "onLoad", function() {
          //after map loads, connect to listen to mouse move & drag events
          dojo.connect(map, "onMouseMove", showCoordinates);
          dojo.connect(map, "onMouseDrag", showCoordinates);
        var tiledMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://maps.cityofdayton.org/ArcGIS/rest/services/Maps/HansenSRbase_Tile/MapServer");
        map.addLayer(tiledMapServiceLayer);
        locator = new esri.tasks.Locator("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Locators/ESRI_Geocode_USA/GeocodeServer");
        dojo.connect(locator, "onAddressToLocationsComplete", showResults);
      function locate() {
        map.graphics.clear();
        var add = dojo.byId("address").value.split(",");
        var address = {
          Address : add[0],
          City: add[1],
          State: add[2],
          Zip: add[3]
        locator.addressToLocations(address,["Loc_name"]);
      function showResults(candidates) {
        var candidate;
        var symbol = new esri.symbol.SimpleMarkerSymbol();
        var infoTemplate = new esri.InfoTemplate("Location", "Address: ${address}<br />Score: ${score}<br />Source locator: ${locatorName}");
        symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_DIAMOND);
        symbol.setColor(new dojo.Color([255,0,0,0.75]));
        var points =  new esri.geometry.Multipoint(map.spatialReference);
        for (var i=0, il=candidates.length; i<il; i++) {
          candidate = candidates;
          if (candidate.score > 90) {
            var attributes = { address: candidate.address, score:candidate.score, locatorName:candidate.attributes.Loc_name };
            var graphic = new esri.Graphic(candidate.location, symbol, attributes, infoTemplate);
            map.graphics.add(graphic);
            map.graphics.add(new esri.Graphic(candidate.location, new esri.symbol.TextSymbol(attributes.address).setOffset(0, 8)));
            points.addPoint(candidate.location);
        map.setExtent(points.getExtent().expand(3));
      function showCoordinates(evt) {
        //get mapPoint from event
        var mp = evt.mapPoint;
        //display mouse coordinates
        dojo.byId("info").innerHTML = mp.x + ", " + mp.y;
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="tundra">
    Address : <input type="text" id="address" size="60" value="4604 Silver Oak St, Dayton, OH, 45424" /> <i>(Address, City, State, Zip)</i>
    <input type="button" value="Locate" onclick="locate()" /><br />
    <br />
    <div id="map" style="position:relative; width:1200px; height:600px; border:1px solid #000;">
      <span id="info" style="position:absolute; right:25px; bottom:5px; color:#000; z-index:50;"></span>
  </body>
</html>
RichardBailey
Thanks Alex, I appreciate the quick reply.  I was pretty sure that the geometry service was the way to go, I just couldn't find an example that was enough like mine to borrow from.  I used the links you provided and attempted to figure it out my own but was unable.  Would you happen to have the time to drop a few lines of code here to help me out?  Usually I would try and try until I had it working but I'm on a huge time crunch for this.
Thanks again,
Richard
