Progressbar with BasemapGallery
4529
6
09-30-2015 03:46 PM
JulieBiju
Thank U.
Added map loading progress bar successfully in my webapp.
I noticed one issue which is if I pan/Zoom  altareeqENG map   and the  map(altareeqENG )  not loaded completely,In the mean time If I change map option to Bing then progressbar will not disappear after the map loads completely.
Is it require to call hideLoading from some other way?
code pasted below
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior
    of the samples on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title>Basemap Gallery - Bing Maps</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
  <style type="text/css">
    html,
    body,
    #mapDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      z-index: -1;
      -moz-border-radius: 4px;
      overflow: hidden;
    .claro .dijitButtonText {
      color: #03c;
      font-family: Arial, Helvetica, sans-serif font-weight: bold;
    .claro td.dijitMenuItemLabel {
      color: #03c;
      font-family: Arial, Helvetica, sans-serif font-weight: 500;
    .auto-style1 {}
    .auto-style2 {
      height: 20px;
    .auto-style3 {
      height: 20px;
    .auto-style6 {
      height: 2%;
      width: 279px;
    .auto-style7 {
      width: 279px;
    #TxtAltareeqEng {
      width: 55px;
    #TxtAltareeqEng0 {
      width: 55px;
  </style>
  <script>
      var dojoConfig = {
          parseOnLoad: false,
          async: true,
          tlmSiblingOfDojo: false,
          packages: [{
              location: location.pathname.replace(/\/[^/]+$/, '') + "/ncam"
  </script>
  <script type="text/javascript" src="http://js.arcgis.com/3.14/"></script>
  <script type="text/javascript">
      window.onerror = function (msg, url, linenumber) {
          alert('Error message: ' + msg + '\nURL: ' + url + '\nLine Number: ' + linenumber);
          return true;
      var map, basemapGallery;
      require([
         "esri/map",
    "esri/graphic",
    "esri/layers/ArcGISDynamicMapServiceLayer",
    "esri/layers/GraphicsLayer",
    "esri/geometry/Extent",
    "esri/geometry/Point",
    "esri/geometry/Polyline",
    "esri/SpatialReference",
    "esri/symbols/PictureMarkerSymbol",
    "esri/symbols/SimpleLineSymbol",
    "esri/InfoTemplate",
    "esri/dijit/Basemap",
    "esri/dijit/BasemapGallery",
    "esri/dijit/BasemapLayer",
    "esri/graphicsUtils",
    "dojo/_base/array",
    "dojo/parser",
     "dojo/on",
    "dojo/dom",
    "dojo/_base/lang",
    "dijit/MenuItem",
    "dijit/registry",
    "ncam/DirectionalLineSymbol",
    "dijit/Menu",
    "dijit/layout/ContentPane",
    "dijit/form/Button",
    "dijit/form/RadioButton",
    "dijit/form/DropDownButton",
    "dojo/domReady!"
        function (
          Map,
    Graphic,
    ArcGISDynamicMapServiceLayer,
    GraphicsLayer,
    Extent,
    Point,
    Polyline,
    SpatialReference,
    PictureMarkerSymbol,
    SimpleLineSymbol,
    InfoTemplate,
    Basemap,
    BasemapGallery,
    BasemapLayer,
    graphicsUtils,
    array,
    parser,
    on,
    dom,
    lang,
    MenuItem,
    registry,
            parser.parse();
            var TareeqENG, TareeqARB;
            var graphicsLayer;
            var AltareeqArb, AltareeqEng;
            loading = dom.byId("loadingImg");  //loading image. id
            map = new Map("mapDiv", {
                center: [6.389, 36.054],
                zoom: 4,
                basemap: 'topo'
            map.on('load', function () {
                createBasemapGallery();
            on(map, "update-start", showLoading);
            on(map, "update-end", hideLoading);
            registry.byId("radioOne").on("change", function (isChecked) {
                if (isChecked) {
                    registry.byId("LnkLastPosition").set("label", "LastPosition");
                    registry.byId("LnkTracking").set("label", "Tracking");
            }, true);
            registry.byId("radioTwo").on("change", function (isChecked) {
                if (isChecked) {
                    registry.byId("LnkLastPosition").set("label", "الموقف الأخير");
                    registry.byId("LnkTracking").set("label", "التتبع");
            }, true);
            registry.byId("LnkLastPosition").on("click", LastPosClick);
            registry.byId("LnkTracking").on("click", LastPosClick);
            function createBasemapGallery() {
                AltareeqEng = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...";
                AltareeqArb = "http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer";
                //Manually create a list of basemaps to display
                var basemaps = [];
                TareeqENG = new Basemap({
                    layers: [new ArcGISDynamicMapServiceLayer(AltareeqEng)],
                    title: "Al-Tareeq(ENG)"
                basemaps.push(TareeqENG);
                TareeqARB = new Basemap({
                    layers: [new ArcGISDynamicMapServiceLayer(AltareeqArb)],
                    title: "Al-Tareeq(AR)"
                basemaps.push(TareeqARB);
                BingMapsRoad = new Basemap({
                    layers: [new BasemapLayer({
                        type: "BingMapsRoad"
                    title: "BingMaps-Road"
                basemaps.push(BingMapsRoad);
                BingMapsAerial = new Basemap({
                        type: "BingMapsAerial"
                    title: "BingMaps-Aerial"
                basemaps.push(BingMapsAerial);
                BingMapsHybrid = new Basemap({
                        type: "BingMapsHybrid"
                    title: "BingMaps-Aerial-Labels"
                basemaps.push(BingMapsHybrid);
                basemapGallery = new BasemapGallery({
                    showArcGISBasemaps: false,
                    basemaps: basemaps,
                    bingMapsKey: "Key",
                    map: map
                basemapGallery.startup();
                graphicsLayer = new GraphicsLayer();
                map.addLayer(graphicsLayer);
                //BasemapGallery.startup isn't needed because we aren't using the default basemap, instead
                //we are going to create a custom user interface to display the basemaps, in this case a menu.
                array.forEach(basemapGallery.basemaps, function (basemap) {
                    //Add a menu item for each basemap, when the menu items are selected
                    registry.byId("bingMenu").addChild(new MenuItem({
                        label: basemap.title,
                        onClick: lang.hitch(this, function () {
                            this.basemapGallery.select(basemap.id);
                /*Select that basemap that you want to be initially displayed*/
                basemapGallery.select(TareeqENG.id);
            function showLoading() {
                esri.show(loading);
                map.disableMapNavigation();
                map.hideZoomSlider();
            function hideLoading(error) {
                esri.hide(loading);
                map.enableMapNavigation();
                map.showZoomSlider();
            function LastPosClick() {
                map.infoWindow.hide();
                var colourstyle = "images/sphere-blue-dark-16x16.png"
                var Status = "status";
                var procname = "procname";
                var location = "location";
                var Driver = "Drv";
                var strhotspot = "strhotspot";
                var geomPoint1 = new Point(58.46236, 23.61581);
                var geomPoint2 = new Point(59.46236, 23.61581);
                var geomPoint3 = new Point(60.43362666666, 23.583081666666);
                var polyline = new Polyline(new SpatialReference(4326));
                polyline.addPath([geomPoint1, geomPoint2, geomPoint3]);
                var symbol = new PictureMarkerSymbol({
                    "url": colourstyle,
                    "height": 16,
                    "width": 16,
                    "type": "esriPMS"
                //add a basic polyline
                var basicOptions = {
                    style: SimpleLineSymbol.STYLE_SOLID,
                    color: new dojo.Color([0, 0, 0]),
                    width: 2,
                    directionScale: 0.8,
                    directionStyle: "arrow3",
                    directionPixelBuffer: 80
                var basicSymbol = new DirectionalLineSymbol(basicOptions);
                var infoTemplate = new InfoTemplate();
                infoTemplate.content = strhotspot;
                var pointGraphic = new Graphic(geomPoint1, symbol);
                var pointGraphic2 = new Graphic(geomPoint2, symbol);
                var pointGraphic3 = new Graphic(geomPoint3, symbol);
                var lineGraphic = new Graphic(polyline, basicSymbol);
                pointGraphic.setInfoTemplate(infoTemplate);
                pointGraphic2.setInfoTemplate(infoTemplate);
                pointGraphic3.setInfoTemplate(infoTemplate);
                graphicsLayer.add(pointGraphic);
                graphicsLayer.add(pointGraphic2);
                graphicsLayer.add(pointGraphic3);
                graphicsLayer.add(lineGraphic);
                setextent();
                var DivesriLogoImage = dom.byId('DivesriLogoImage');
                var mapDiv = dom.byId('mapDiv');
                mapDiv.style.visibility = "visible";
                DivesriLogoImage.style.visibility = "hidden";
            function setextent() {
                var gextent = graphicsUtils.graphicsExtent(graphicsLayer.graphics).expand(1.2);
                map.setExtent(gextent);
  </script>
</head>
<body class="claro">
  <form id="form1" >
    <div style="width: 100%; height: 100%">
      <table id="Tablecontrols0" style="font-size: 15px; z-index: 101; background-color: #5B748B; width: 100%; height: 100%;">
        <tr style="font-family: Times New Roman">
          <td style="border-style: none; background-color: #496277; " valign="top" class="auto-style6">
            <input type="radio" data-dojo-type="dijit/form/RadioButton" name="uilanguage" id="radioOne" checked value="English"/><label for="radioOne">English</label><br />
            <input type="radio" data-dojo-type="dijit/form/RadioButton" name="uilanguage" id="radioTwo" value="العربية"/><label for="radioTwo">العربية</label>
          </td>
          <td align="left" style="border-style: none; background-color: #496277; height: 2%;" valign="top" class="auto-style3">
          </td>
        </tr>
          <td style="border-style: none;" valign="top" bgcolor="#496277" class="auto-style7">
            <table id="Tablecontrols" style="border-color: #F2F0EE; font-size: 15px; z-index: 101;
            background-color: #496277; width:auto; height: 274px; font-family: verdana; color: tomato; font-weight: bold; border-top-style: none;" align="left">
                <td rowspan="1" valign="top" height="10px" class="auto-style1">
                </td>
                <td rowspan="1" style="border-style: none;" valign="top" height="10px">
                </td>
              </tr>
                <td rowspan="1" style="font-weight: bold; " valign="top" height="10px" class="auto-style1">
                </td>
                </td>
              </tr>
                <td style="font-weight: bold; " valign="top" height="10" class="auto-style1" colspan="2">
                </td>
              </tr>
                <td style="font-weight: bold; text-align: center; " valign="top" class="auto-style2">
                  <button dojotype="dijit/form/Button" id="LnkLastPosition" style="font-family: Arial; font-size: x-small; font-weight: normal">
                    Last Position</button>
                </td>
                <td style="border-style: none; text-align: center;" valign="top" class="auto-style3">
                  <button dojotype="dijit/form/Button" id="LnkTracking" style="font-family: Arial; font-size: x-small; font-weight: normal">
                    Tracking</button>
                </td>
              </tr>
                <td colspan="2" rowspan="1" style="border-top: 2px solid #547289; border-bottom: 2px solid #547289; font-weight: bold;  position: static;
                    height: 100%; text-align: left; width: 30%; border-left-width: 2px; border-right-width: 2px;" valign="top" align="left">
                  <div id="Something"></div>
                  <div style="width: 300px; height: 356px; overflow: scroll"></div>
                </td>
              </tr>
            </table>
          </td>
          <td style="border-style: none; background-color: white;  width: 100%; height:100%;" valign="top" id="td11">
            <div id="mapDiv"  dojotype="dijit/layout/ContentPane" region="center" style="border:1px solid #000; visibility: visible; height: 100%;">
                  <img id="loadingImg" src="images/rotating globe 1.gif" style="position:absolute; right:512px; top:277px; z-index:100; width: 40px; height: 40px;" />
              <div style="position:absolute; right:50px; top:100px; z-Index:99;">
                <button id="dropdownButton" label="Basemaps" data-dojo-type="dijit/form/DropDownButton">
                  <div data-dojo-type="dijit/Menu" id="bingMenu">
                    <!--The menu items are dynamically created using the basemap gallery layers-->
                  </div>
                </button>
              </div>
            </div>
            <div id="DivesriLogoImage"  style="background-color: #FFFFFF; width: 80%; height:99.8%; visibility: hidden; position: absolute; top: 72px;" align="center">
            </div>
          </td>
        </tr>
      </table>
    </div>
  </form>
</body>
</html>
RobertScheitlin__GISP
Julie,
  I could not find a reason why the progress image was not hidden as it should be, so as a workaround I just hide the dropdown until the map is done drawing the selected basemap. Find a new zip attached
Julie,
  A couple of things:
1. esri.show is legacy code you need to require esri/domUtils for AMD.
2. I added "loading" as a global var.
3. I changed on(map, "update-start, showLoading); to map.on("update-start", showLoading);
4. I moved the map.on("update-start", showLoading); events to before the map.on('load',...  line.
5. Changed legacy esri.show(loading); to domUtils.show(loading);
JeffPace
Robert,
as a side note, I dont see domUtils in the 4.0beta.  should we be switching to domStyle.set(node, "display', 'none')?
Kelly Hutchins
Jeff,
   Probably just not added yet as it is more of a utility class and likely has low priority.
JulieBiju
Robert,
Thank U so much.
Yes I done all these changes, But still that issue exists.
Try to change the layer from basemap dropdown before firing the hideLoading. function from the initial layer.
Julie,
JulieBiju
Robert,
Yes This s the correct logic and working fine.
