Programmatically Access Rasters from Mosaic Dataset Image Service using Javascript API
3203
10-30-2020 11:26 AM
tigerwoulds
Let me preface this with the fact that I am not a GIS Developer, more of a GIS Analyst with minimal programming experience. I have around 150 rasters to publish that will be used in a web map.  Running Federated ArcGIS Enterprise 107 and Image Server 107.
I am trying to publish these rasters so they work with an existing web map using arcgis jsapi 4.
Rather than publishing 150 individual services, I have published a mosaic dataset as a single service to my Image Server. How can I access each raster programmatically?
In ArcCatalog I can query/select rasters in a mosaic dataset by it's Name - trying to replicate this in the js api.
Are there any examples out there? I would like to access individual rasters using a unique url.
Thanks!
Gianna_BBSRC
Hi there,
I've long struggled through this exact question. You can access each raster programmatically.
Have a look at this website which I created to select from 440 different rasters using two sliders (woodland planting scenario on the left and 'time from present' at the bottom) and a checkbox (selects different rasters with or without areas with deep peat soils).
Put very simply, it's done by changing the DimensionalDefinition within MosaicRule for each selection.
You can have a look at the script on github. Any specific questions, I'm happy to help.
Cheers,
Gianna
Gianna_BBSRC
Hi there,
Cheers,
Gianna
tigerwoulds
Thanks so much! Your web map is really impressive. I think I have what I need to figure it out from here.
JohnGrayson
Esri Alum
Depending on the how the ImageryLayer was published, there could be several different ways to only display certain information.  For your use-case, setting the definitionExpression based on the Name field should be one way.  When trying to override the default settings as published by the service author, I normally clear/reset the definitionExpression and mosaicRule properties as soon as the layer is loaded, and then set these properties as needed based on the task at hand.
