programitically invoking on click behiour of Feature Layer
1283
09-20-2013 05:46 AM
vinayb
HI All,
  how can i pragmatically invoke on click behavior of feature layer at a particular portion of Map i don't have co ordinates.
JohnGravois
we don't have a prepackaged way for you to refine graphic mouse events based on geography, so you would have to perform your own check based on the current extent (map.extent property) and connect and disconnect the event manually.
this conceptual article provides an excellent in depth discussion of event handling
Working with the API > Inside events
https://developers.arcgis.com/en/javascript/jshelp/inside_events.html
vinayb
problem is lets say in world country map , if i want to programitically click on country say south africa then how do i do that.
JohnGravois
do you have a feature layer loaded which displays a graphic for the country?
