Programatically Set Default TravelTime TravelMode in RouteTask
1045
08-24-2020 08:01 AM
CamilleSevigny
Hi, I am trying to  programatically set/use the default travel mode of "TravelTime" in a RouteTask.
// Setup the route parameters
var routeParams = new RouteParameters({
   returnDirections: true,
   stops: new FeatureSet({
      features: view.graphics.toArray()
   travelMode: ?????? //How do I set this to a default TravelMode of "Travel Time", or "Drive Time", or "Truck"?
// Get the route
routeTask.solve(routeParams).then(function(data) {
   //Do Stuff Here......
Is it possible to use the default travel modes that arcGIS has for shortest time, shortest distance, and truck routing?
Noah-Sager
I think this is the documentation you are looking for:
RouteParameters | ArcGIS API for JavaScript 4.16
Note that a valid travelMode property is will be dependent on the Network Analyst server to which the request is sent.
