The article you are trying to access is permanently deleted.
var xmuss = mapPoint.x - ((mapPoint.x - this.inputPoints[this.inputPoints.length-2].x)/2);
var ymuss = mapPoint.y - ((mapPoint.y - this.inputPoints[this.inputPoints.length-2].y)/2);
var winkelmuss = (Math.atan2((this.inputPoints[this.inputPoints.length-2].y - mapPoint.y), (this.inputPoints[this.inputPoints.length-2].x - mapPoint.x))*180)/Math.PI;
var pt = new esri.geometry.Point(xmuss, ymuss, this._map.spatialReference);
var textSymbol = new esri.symbol.TextSymbol();
textSymbol.setColor(new dojo.Color([0,0,0])).setFont(new esri.symbol.Font("12pt").setWeight(esri.symbol.Font.WEIGHT_BOLD));
var gemessen = '123';
textSymbol.text = dojo.number.format(gemessen.toFixed(1), {pattern: this.numberPattern}) + zeichen;
textSymbol.angle = 90;
this.textGraphic=new esri.Graphic();
this.textGraphic.setSymbol(textSymbol);
this.textGraphic.setGeometry(pt);
this._map.graphics.add(this.textGraphic);
this.measureGraphics.push(this.textGraphic);
//in the init()
// get print templates from the export web map task
var printInfo = esri.request({
"url": app.printUrl,
"content": { "f": "json" }
printInfo.then(handlePrintInfo, handleError);
//Print Funktion
function handlePrintInfo(resp)
var layoutTemplate, templateNames, mapOnlyIndex, templates;
layoutTemplate = dojo.filter(resp.parameters, function(param, idx) {
return param.name === "Layout_Template";
if ( layoutTemplate.length == 0 ) {
console.log("print service parameters name for templates must be \"Layout_Template\"");
return;
templateNames = layoutTemplate[0].choiceList;
// remove the MAP_ONLY template then add it to the end of the list of templates
mapOnlyIndex = dojo.indexOf(templateNames, "MAP_ONLY");
if ( mapOnlyIndex > -1 ) {
var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
templateNames.push(mapOnly);
// create a print template for each choice
templates = dojo.map(templateNames, function(ch) {
var plate = new esri.tasks.PrintTemplate();
plate.layout = plate.label = ch;
plate.format = "PDF";
plate.layoutOptions = {
"authorText": "Stadt Osnabrück Fachbereich Städtebau",
"copyrightText": "Copyright Stadt Osnabrück",
"legendLayers": [],
"titleText": "Messen",
"scalebarUnit": "Kilometers"
return plate;
// create the print dijit
app.printer = new esri.dijit.Print({
"map": app.map,
"templates": templates,
url: app.printUrl
}, dojo.byId("print_button"));
app.printer.startup();
function handleError(err) {
console.log("Something broke: ", err);
}Unfortunately, I'm not aware of a way to remove the color flag from the JSON without doing some manual manipulation...
dojo.forEach(_markupTool.markupTextLayer.graphics, function (item) {
//Remove color property from each graphics' symbol - trying GP Print Task bug workaround
if (item && item.symbol && item.symbol.color) {
delete item.symbol.color;
*snip* {"id":"graphicsLayer47","featureCollection":{"layers":[{"layerDefinition":{"name":"pointLayer","geometryType":"esriGeometryPoint"},"featureSet":{"geometryType":"esriGeometryPoint","features":[{"geometry":{"x":-13619523.035374189,"y":6030400.527597526,"spatialReference":{"wkid":102100}},"symbol":{"color":[0,0,0,255],"type":"esriTS","angle":0,"xoffset":0,"yoffset":0,"text":"linguist","align":"start","decoration":"none","rotated":false,"kerning":true,"font":{"size":"16pt","style":"normal","variant":"normal","weight":"bold","family":"Arial"}}}]}}]}}],"exportOptions": *snip*
function scrubPrintTask(ioArgs) {
// inspect ioArgs
//console.log(ioArgs.url, ioArgs.content);
if (ioArgs.url.indexOf("ExportWebMap") > -1) {
if (ioArgs.content.Web_Map_as_JSON) {
ioArgs.content.Web_Map_as_JSON = ioArgs.content.Web_Map_as_JSON.replace('"symbol":{"color":[0,0,0,255],"type":"esriTS"', '"symbol":{"type":"esriTS"');
// don't forget to return ioArgs.
return ioArgs;
"symbol":{
"type":"esriTS",
"angle":45,
"xoffset":0,
"yoffset":0,
"text":"This is a test.",
"align":"middle",
"rotated":false,
"kerning":true,
"font":{
"size":"16pt",
"style":"normal",
"variant":"normal",
"weight":"bold",
"family":"Arial"
ioArgs.content.Web_Map_as_JSON = ioArgs.content.Web_Map_as_JSON.replace(/\"size\":\"16pt\"/g, '"size":16'); ioArgs.content.Web_Map_as_JSON = ioArgs.content.Web_Map_as_JSON.replace(/\"angle\":/g, '"angle":-');
"mapOptions": {
"showAttribution": true,
"extent": {
"xmin": 283587.7543757293,
"ymin": 78359,
"xmax": 342600.2456242707,
"ymax": 113602,
"spatialReference": {
"wkid": 27700
"wkid": 27700
"scale": 155427.79855309209
"operationalLayers": [{
"id": "mainbasemaps",
"title": "mainbasemaps",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"url": "http://eddc-gis2/arcgis/rest/services/BaseMapOSNonTiled/MapServer",
"visibleLayers": null,
"layers": []
"id": "altbasemaps",
"title": "altbasemaps",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"url": "http://eddc-gis2/arcgis/rest/services/alt_basemaps/MapServer",
"layers": []
"id": "aerialmaps",
"title": "aerialmaps",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"url": "http://eddc-gis2/arcgis/rest/services/LIVEinternal/aerials/MapServer",
"layers": []
"id": "mainmap",
"title": "mainmap",
"opacity": 0.9,
"minScale": 0,
"maxScale": 0,
"url": "http://eddc-gis2/arcgis/rest/services/test/emap2/MapServer",
"visibleLayers": [],
"layers": []
"id": "graphicsLayer0",
"minScale": 750,
"maxScale": 0,
"featureCollection": {
"layers": []
"id": "usergraphics",
"minScale": 0,
"maxScale": 0,
"layers": [{
"layerDefinition": {
"name": "pointLayer",
"geometryType": "esriGeometryPoint"
"featureSet": {
"geometryType": "esriGeometryPoint",
"features": [{
"geometry": {
"x": 314019.2829638273,
"y": 87077.22170361727,
"wkid": 27700
"symbol": {
"color": [0, 0, 0, 255],
"size": 54,
"angle": 0,
"xoffset": 0,
"yoffset": 0,
"type": "esriSMS",
"style": "esriSMSCircle",
"outline": {
"color": [255, 0, 0, 255],
"width": 0.75,
"type": "esriSLS",
"style": "esriSLSSolid"
"geometry": {
"x": 318090.52800466743,
"y": 84938.78996499417,
"wkid": 27700
"symbol": {
"type": "esriTS",
"horizontalAlignment": "left",
"angle": 0,
"xoffset": 0,
"yoffset": 0,
"text": "text last",
"rotated": false,
"kerning": true,
"font": {
"size": 54,
"style": "normal",
"variant": "normal",
"decoration": "none",
"weight": "normal",
"family": "verdana"
"id": "graphicsLayer1",
"minScale": 0,
"maxScale": 0,
"layers": []
"id": "graphicsLayer2",
"minScale": 0,
"maxScale": 0,
"layers": []
"id": "map_graphics",
"minScale": 0,
"maxScale": 0,
"layers": []
"exportOptions": {
"outputSize": [2125.98, 2362.2],
"dpi": "96"
"layoutOptions": {
"titleText": "",
"authorText": " ",
"copyrightText": "Crown Copyright and database rights 2014 Ordnance Survey 100023746 ",
"scaleBarOptions": {
"metricUnit": "Kilometers",
"metricLabel": "km",
"nonMetricUnit": "Miles",
"nonMetricLabel": "mi"
"legendOptions": {
"id": "mainmap"
"mapOptions": {
"extent": {
"ymin": 78359,
"ymax": 113602,
"wkid": 27700
"wkid": 27700
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"layers": []
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"layers": []
"id": "aerialmaps",
"opacity": 1,
"minScale": 0,
"maxScale": 0,
"layers": []
"id": "mainmap",
"title": "mainmap",
"opacity": 0.9,
"minScale": 0,
"maxScale": 0,
"layers": []
"minScale": 750,
"maxScale": 0,
"layers": []
"minScale": 0,
"maxScale": 0,
"layers": [{
"featureSet": {
"features": [{
"geometry": {
"x": 312785.5723453909,
"y": 85884.63477246207,
"wkid": 27700
"symbol": {
"type": "esriTS",
"angle": 0,
"xoffset": 0,
"yoffset": 0,
"text": "text first",
"rotated": false,
"kerning": true,
"font": {
"size": 54,
"style": "normal",
"weight": "normal",
"family": "verdana"
"geometry": {
"x": 311140.62485414237,
"y": 84239.68728121354,
"wkid": 27700
"symbol": {
"size": 54,
"angle": 0,
"xoffset": 0,
"yoffset": 0,
"type": "esriSMS",
"outline": {
"width": 0.75,
"type": "esriSLS",
"minScale": 0,
"maxScale": 0,
"layers": []
"minScale": 0,
"maxScale": 0,
"layers": []
"minScale": 0,
"maxScale": 0,
"layers": []
"exportOptions": {
"dpi": "96"
"layoutOptions": {
"titleText": "",
"authorText": " ",
"legendOptions": {
"id": "mainmap"
