Problems with layers from Arcgis online on openlayers.
3409
01-15-2014 03:10 AM
PaoloBarone
Hello everyone, I have some problems to link layers Arcgis online on openlayers. I need some helps please. Here is the code:
HTML Code:
[HTML]
<html>
<head>
<title>Carte</title>
<script src="http://www.openlayers.org/api/OpenLayers.js"></script>
</head>
<body>
<div style="width:100%; height:100%" id="map"></div>
<script defer="defer" type="text/javascript">
  // Constructor of the map
  var map = new OpenLayers.Map('map');
  // Put coordonate
     map.addControl(
                new OpenLayers.Control.MousePosition({
                    prefix: '<a target="_blank" ' +
                        'href="http://spatialreference.org/ref/epsg/4326/">' +
                        'EPSG:4326</a> coordinates: ',
                    separator: ' | ',
                    numDigits: 2,
                    emptyString: 'Mouse is not over map.'
  // Put basemap and layers.
   var layer = new OpenLayers.Layer.OSM( "Simple OSM Map");
   var ol = new OpenLayers.Layer.OSM("Simple carte");
   arcgislayer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
                                            "http://services2.arcgis.com/D0xrg9UqZz6klOA4/arcgis/rest/services/TEST_EHANIA/FeatureServer/0",
                                            {'layers': 'basic'},
                                            {'maxExtent': new OpenLayers.Bounds(-180,-90,180,90),
                                             'maxResolution': "auto"});
   map.addLayer(layer);
   map.zoomToMaxExtent();
  // Put Marker.
     var markers = new OpenLayers.Layer.Markers( "Markers" );
  map.addLayer(markers);
    var size = new OpenLayers.Size(45,50);
    var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
    var icon = new OpenLayers.Icon('http://fc07.deviantart.net/fs71/f/2013/201/6/9/super_mario_png_by_brokenheartdesignz-d6ebndw.png', size, offset);
    markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(4.18,50.28),icon));
    markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(4.18,50.28),icon.clone()));
    //Vector.
   var start_point = new OpenLayers.Geometry.Point(0,10);
var end_point = new OpenLayers.Geometry.Point(30,0);
var point_test = new OpenLayers.Geometry.Point(10,15);
var vector = new OpenLayers.Layer.Vector("Vecteurs");
vector.addFeatures([new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString([start_point, end_point,point_test]).transform(new OpenLayers.Projection("EPSG:4326"), new OpenLayers.Projection("EPSG:900913")))]);
map.addLayers([ol,vector]);
map.setCenter(new OpenLayers.LonLat(0, 5), 3);
    // switcheur.
    map.addControl(new OpenLayers.Control.LayerSwitcher());
</script>
</body>
</html>[/HTML]
The Url service is " "http://services2.arcgis.com/D0xrg9UqZz6klOA4/arcgis/rest/services/TEST_EHANIA/FeatureServer/0 "
Your help is precious. Thank you.
JonathanUihlein
Hi Marco!
This looks to be an OpenLayers issue and not an ESRI JSAPI issue.
You may want to ask your question at http://gis.stackexchange.com/
PaoloBarone
Hi Marco!
Hi  Jon.uihlein,
Ok i go to the site.  Thanks you for your help.
