Problems with JS API 4.0 mapView: wrapAroound property doesn't hold the Graphics when WrapAround is done
2514
07-14-2016 10:32 AM
NikhilSharma
Refer the following sample:
https://developers.arcgis.com/javascript/latest/sample-code/get-started-graphics/live/index.html
Check the above sample.Keep panning to the right. The graphics will not show after map wrapped around. Is their a workaround to this issue?
BjornSvensson
Esri Alum
Hi Nikhil,
Thanks for taking a look at our 4.0 API.  As mentioned on https://developers.arcgis.com/javascript/latest/guide/functionality-matrix/index.html, wraparound for features is not supported in 4.0 but is planned for 4.1.
