problems saving datetime to SDE via applyedits
3543
7
02-06-2014 07:25 AM
JustinClowes
I'm trying to create a new feature using featureLayer.applyEdits.
I pass in the geometry and attributes and this is saved to the database correctly.
When I try and save a datetime attribute I get the error : "Error saving new find : Unable to complete operation".
Does anyone know what format the datetime needs to be in?
I am using ArcGIS Server v10 with SQL Server 2008.
Thanks. See my code below:
var datetime = dojo.date.locale.parse("07/02/2014 13:54",
                datePattern:"dd/MM/yyyy",
                timePattern:"HH:mm"
var attr = {
"DATE_TIME_J" : datetime
var ng = new esri.Graphic(Point, null, attr, null);
featureLayer.applyEdits([ng], null, null, ........
martinschmoll
I use the .valueOf() function to pass the current date into Oracle via applyEdits() on a FeatureService:
... "DATETIME": new Date().valueOf(); ...
martinschmoll
JeffPace
                timePattern:"HH:mm"
var attr = {
if the field you are trying to write to a date field? or a string
JustinClowes
thanks, yes I'm trying to write to a datetime field (in SQL Server) and I need to include both the date and the time.
I need to write a specific date + time, not the current date
martinschmoll
I thought it was obvious, but the valueOf() function can be used on any date!  We use Oracle, and this was the solution for us.  So in your example try:
var attr = {
"DATE_TIME_J" : datetime.valueOf()
JeffPace
mschmoll is is right
By passing datetime, you are actually sending the parsed string to the database
but using valueof(), you are likely sending the actual datetime value
JustinClowes
Thanks, that works perfectly with SQL Server too. Problem solved.
JeffPace
great to hear! please mark mschmoll's post as the answer by checking the checkmark on his post so he gets credit for it.
