Problems registering polygons
826
12-13-2021 09:47 PM
BraulioCordova
I am developing a solution for registering polygons. Through a featureacces service. But I get an error.
 featureForm.on("submit", function () {
      if (editFeature) {
        const updated = featureForm.getValues();
        editFeature.attributes["id_dist"] = ubigeo;
        editFeature.attributes["anio"] = (new Date()).getFullYear();
        editFeature.attributes["cep"] = generateUUID();
        editFeature.attributes["estado"] = "Activo";
        editFeature.attributes["nombre_espacio_publico"] = updated["nombre_espacio_publico"];
        editFeature.attributes["tipologia"] = updated["tipologia"];
        editFeature.attributes["dimension"] = updated["dimension"];
        editFeature.attributes["nro_viviendas_colindantes"] = updated["nro_viviendas_colindantes"];
        editFeature.attributes["nro_habitantes"] = updated["nro_habitantes"];
        editFeature.attributes["user_sipcopm"] =usuariosipcopm;
        editFeature.attributes["fecha_registro"] = formatDate(new Date());
        editFeature.attributes["estado"] = "REGISTRADO";
        const edits = {
              updateFeatures: [editFeature]
        applyEditsToIncidents(edits);
        featureLayer.refresh();
        unselectFeature();
featureLayer
        .applyEdits(params)
        .then(function (editsResult) {
          if (editsResult.addFeatureResults.length > 0 || editsResult.updateFeatureResults.length > 0) {
            unselectFeature();
            let objectId;
            if (editsResult.addFeatureResults.length > 0) {
              objectId = editsResult.addFeatureResults[0].objectId;
              document.getElementById("addFeatureDiv").style.display = "none";
              document.getElementById("updateInstructionDiv").style.display = "none";
              document.getElementById("featureUpdateDiv").style.display = "block";
            } else {
              featureForm.feature = null;
              objectId = editsResult.updateFeatureResults[0].objectId;
            selectFeature(objectId);
          else if (editsResult.deleteFeatureResults.length > 0) {
            document.getElementById("addFeatureDiv").style.display = "block";
            document.getElementById("updateInstructionDiv").style.display = "block";
            document.getElementById("featureUpdateDiv").style.display = "none";
            document.getElementById("opcionesfeatureDiv").style.display = "none";
        }).catch(function (error) {
          console.error(
            "[ applyEdits ] FAILURE: ",
            error.code,
            error.name,
            error.message
          console.log("error aqui salio= ", error);
The problem is by geometry. It works with points, but with polygon. It does not allow me. Please a little help.
Tags (1)
CourtneyMenikheim
What is the error message?
Are you using the 4.x or 3.x api?
Is this feature layer available for testing? Can you provide an example of one of the Graphics in you applyEdits call?
Courtney Menikheim
BraulioCordova
