Problem with using OAuth2.0 app credential authentication
2124
10-27-2023 02:01 PM
GIS412
Hello,
I'm new to the ArcGIS API for Javascript. I'm currently working on a project  that requires me to use a rest endpoint on our enterprise portal. This will be public facing, so there is no need to have people accessing this page to ask for login information. The user should be able to click the link to the webpage and it should open up.
I've read up on the documentation here:
https://developers.arcgis.com/documentation/mapping-apis-and-services/security/app-credential-authen...
Going with OAuth2.0 with app credential authentication. I've created my clientid and client secret. I've created my small project. Here's the code.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1, user-scalable=no"
    <title>Public Map with App Credentials Authentication</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.28/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.28/"></script>
    <script>
      require([
        "esri/Map",
        "esri/views/MapView",
        "esri/layers/FeatureLayer",
        "esri/identity/OAuthInfo",
        "esri/identity/IdentityManager",
        "esri/arcgis-rest-auth/ApplicationSession",
      ], (Map, MapView, FeatureLayer, OAuthInfo, IdentityManager, ApplicationSession) => {
        const session = new ApplicationSession({
          clientId: 'my_client_id',
          clientSecret: 'my_client_secret',
          grant_type:'client_credentials',
          duration: 60
        session.getToken("https://www.arcgis.com/sharing/rest/oauth2/token")
          .then(function(response) {
            console.log('this is the response ', response);
          }).catch(function(error) {
            // request failed, handle errors
            console.log('error ', error);
        // App Credentials configuration
        const oauthInfo = new OAuthInfo({
          appId: "my_client_id",
          popup: false, // No popup for user login
          portalUrl: "my_enterprise_portal",
        IdentityManager.registerOAuthInfos([oauthInfo]);
        // Initialize the map and view
        const map = new Map({
          basemap: "topo-vector",
        const view = new MapView({
          container: "viewDiv",
          map: map,
          zoom: 12,
          center: [-122.64, 47.577],
        // Load the feature layer after signing in with App Credentials
        IdentityManager.checkSignInStatus(oauthInfo.portalUrl).then(() => {
          // Create a feature layer from the REST endpoint
          const featureLayer = new FeatureLayer({
            url: "my_rest_endpoint",
          map.layers.add(featureLayer); // Add the feature layer to the map
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
Because of security, I've chosen to withhold my clientid, client secret, enterprise portal url, and rest endpoint.
When I run this code and check the console via developer tools, I'm getting these errors.
Failed to load resource: the server responded with a status of 404 ()
(index):31. ApplicationSession.js:1 Failed to load resource: the server
Error: scriptError: https://js.arcgis.com/4.28/esri/arcgis-rest-auth/ApplicationSession.js
at h ((index):6)
at HTMLScriptElement.<anonymous> ((index):30)
(anonymous) @ (index):31
This leads me to believe there is a problem with ApplicationSession.js? I've double checked my node directory and see it exists. It is in this directory (which is in a subdirectory of my main project):
Can anyone point me in the right direction? I've been lost on this for the past few days and am not sure how to move forward from here.
Sage_Wall
Hi @GIS412 ,
Application credentials are for server side use only and shouldn't be used in client side code. Anyone with basic web development skills could open the webpage, look at the source code, get the client secret and hack your organization. Additionally application credentials are only to be used for accessing location services not for accessing secured content.
https://developers.arcgis.com/documentation/mapping-apis-and-services/security/types-of-authenticati...
If you want the public to be able to access the service without logging in I would suggest making the service publicly available.
