Problem with set maxZoom for map.
1195
05-05-2014 06:05 PM
NoppadonHimananto
My map has 21 levels, and At begin, I set maxZoom on constructor at level 19.
this is my code.
var lods = [     {"level" : 0, "resolution" : 156543.03392800014, "scale" : 5.91657527591555E8},     {"level" : 1, "resolution" : 78271.51696399994, "scale" : 2.95828763795777E8},     {"level" : 2, "resolution" : 39135.75848200009, "scale" : 1.47914381897889E8},     {"level" : 3, "resolution" : 19567.87924099992, "scale" : 7.3957190948944E7},     {"level" : 4, "resolution" : 9783.93962049996, "scale" : 3.6978595474472E7},     {"level" : 5, "resolution" : 4891.96981024998, "scale" : 1.8489297737236E7},     {"level" : 6, "resolution" : 2445.98490512499, "scale" : 9244648.868618},     {"level" : 7, "resolution" : 1222.992452562495, "scale" : 4622324.434309},     {"level" : 8, "resolution" : 611.4962262813797, "scale" : 2311162.217155},     {"level" : 9, "resolution" : 305.74811314055756, "scale" : 1155581.108577},     {"level" : 10, "resolution" : 152.87405657041106, "scale" :  577790.554289},     {"level" : 11, "resolution" : 76.43702828507324, "scale" : 288895.277144},     {"level" : 12, "resolution" : 38.21851414253662, "scale" : 144447.638572},     {"level" : 13, "resolution" : 19.10925707126831, "scale" : 72223.819286},     {"level" : 14, "resolution" : 9.554628535634155, "scale" : 36111.909643},     {"level" : 15, "resolution" : 4.77731426794937, "scale" : 18055.954822},     {"level" : 16, "resolution" : 2.388657133974685, "scale" : 9027.977411},     {"level" : 17, "resolution" : 1.1943285668550503, "scale" : 4513.988705},     {"level" : 18, "resolution" : 0.5971642835598172, "scale" : 2256.994353},     {"level" : 19, "resolution" : 0.29858214164761665, "scale" : 1128.497176},     {"level" : 20, "resolution" : 0.1492910708238083, "scale" : 564.248588},     {"level" : 21, "resolution" : 0.0746455354119042, "scale" : 282.124294}     ];     map = new Map("map",{      lods: lods,      center:[100.543623,13.703039],      zoom: 18,      maxZoom: 19,      fadeOnZoom: true     });
On the later... I need to set maxZoom again to different level. But I can't find the way to set that.
In api reference: https://developers.arcgis.com/javascript/jsapi/map-amd.html I found only getMaxZoom() method, but it don't have setMaxZoom() method.
Is it possible to set maxZoom again after set it at constructor.
thanks for help
JeffPace
like LOD, once you set maxZoom it can not be changed.
JeffPace
