Problem with PictureFillSymbol in 4.2
2109
02-27-2017 06:53 AM
JonCrain
I'm having issues with PictureFillSymbol.
Using this code
var polygon = new Polygon({
    rings: [
            [-97.06138, 32.837, 0],
            [-100.06133, 35.836, 0],
            [-100.06124, 32.834, 0],
            [0, 0, 0],
            [0, 0, 0],
            [0, 0, 0],
            [0, 0, 0]
    hasZ: false,
    hasM: false,
    spatialReference: { wkid: 4326 }
// This works
// var fillSymbol = new SimpleFillSymbol({
//   color: new Color([227, 139, 79, 0.8]),
//   outline: { // autocasts as new SimpleLineSymbol()
//     color: new Color([255, 255, 255]),
//     width: 1
// This gives an error
var fillSymbol = new PictureFillSymbol({
    url: url,
    width: 12,
    height: 12,
    xoffset: 0,
    xscale: 1,
    yoffset: 0,
    yscale: 1,
    outline: {
        width: 1
var polygonGraphic = new Graphic({
    geometry: polygon,
    symbol: fillSymbol
layer.add(polygonGraphic);‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
I get this error
Uncaught TypeError: Right-hand side of 'instanceof' is not an object
    at b.l._getParentSurface (MapView.js:333)
    at b.l._setFillObject (MapView.js:333)
    at b.l.setFill (MapView.js:330)
    at Object.m.styleShape (MapView.js:381)
    at f.render (MapView.js:368)
    at d.renderChild (MapView.js:364)
    at d.renderChildren (MapView.js:259)
    at d.render (MapView.js:255)
    at m.renderChild (MapView.js:290)
    at m.d.renderChildren (MapView.js:259)‍‍‍‍‍‍‍‍‍‍‍
I've tried this with a couple different pictures including locally hosted ones and external ones, same error.  I've logged all the objects and they all seem to be created fine, there's just this error on render.
KellyHutchins
Esri Notable Contributor
It looks like there may be an issue with the PFS at 4.2 that is fixed in the next release.  Just to verify can you try this PFS code in your test app?
symbol: new PictureFillSymbol({
url: "https://goo.gl/58GeAx",
width: 240,
height: 240
JonCrain
I inserted your code into my test app and received the same error.
Thanks for looking into it.
KellyHutchins
Great thanks for confirming. This will be fixed in the next release due out soon.
