Problem with overview map size
2151
01-29-2014 06:00 AM
PaulHuppé
I am trying to add the Overview Map Widgit to a specific DIV and to give it a specific size. Part of my code looks like this:
                            overviewMapDijit = new esri.dijit.OverviewMap(
                                {map: mymap,
                                baseLayer: bLayer,
                                height: 80,
                                width: 200},
                                ovDiv);
                        overviewMapDijit.startup();
But, instead of getting an Overview Map of 200x80 pixels, I get a 400x400 pixel Overview Map.  Why does it not respect the size I give it?  Here is a picture showing the elements.
[ATTACH=CONFIG]30934[/ATTACH]
Any ideas?
Paul
PaulHuppé
I did not get any replies yet. BTW, I am using version 3.8 of the API.
Paul
JeffPace
Width of the overview map dijit in screen pixels. The default value is 1/4th the width of the map, unless the HTML element referred to by srcNodeRef has a valid size.
Do you have a size set on "ovDiv"
PaulHuppé
Yes, the size is set with the following class definitions:
.gcviz-overviewMap {
  width: 245px!important;
  height: 100px!important;
PaulHuppé
I set the class to "gcviz-overviewMap", but it gets replaced by the class "esriOverviewMap" when the widget is put in the DIV.
