problem with Legend when subclassing esri.layers.ArcGISDynamicMapServiceLayer
1404
07-21-2011 10:01 AM
MichaelPorter1
I created a subclass of ArcGISDynamicMapServiceLayerEx using the dojo.declare() method.  Everything works great but when I add it to the Legend, the Legend will not recognize it.  Any thoughts on a work around?
Thanks.
derekswingley1
The doc for the legend dijit lists the supported legend types:
The legend supports the following layer types: ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, FeatureLayer. If the layer is an ArcGISDynamicMapServiceLayer or ArcGISTiledMapServiceLayer created using ArcGIS Server 10.0 SP1 or higher the legend is generated using the REST Map Service legend resource.
KMLLayers are also supported. We'll update the doc to reflect this.
MichaelPorter1
Thanks Derek.
The problem is that even though a subclass of ArcGISDynamicServiceLayer is still an instanceof ArcGISDynamicServiceLayer, the Legend will not recognize it.  This does not make sense because the subclass will implement all of the same behaviors, etc.
derekswingley1
I understand, but at v2.4, you're limited to the classes I listed above. What are you doing in your custom class?
MichaelPorter1
A lot of it has to do with representing the class in object form for a table of contents.  I worked around it by adding to esri.layers.ArcGISDynamicMapServiceLayer.prototype, although this is probably not the best solution.
Thanks.
