Problem with font module in Javascript API
1324
10-13-2016 11:25 AM
CesarDuran
Hello,
I have a problem with dynamic services. I am using ESRI Arcgis Server 10.3 and I have several layers as declared as 'ArcGISDynamicMapServiceLayer'.
When the layers show in the API it has a white small halo in all the labels and it makes it very difficult to read. It is a normal map service and is published without halos.
If I use the layers as 'FeatureLayer' the quality of the labels will be better and the halos won't show.
Also if I want to change with setHaloColor() .setHaloSize( ) in 'ArcGISDynamicMapServiceLayer' it wont work.
I am attaching an image with how it looks.
Thank you very much!
RobertScheitlin__GISP
Cesar,
   You will need to re-publish the map service and be sure to un-check the text anti-aliasing this time.
Example
