Has anyone out there done a successful build an app using the version 3.16?
For some reason, dojo's build system doesn't seem to like moment.js, which appears to be a dependency of 3.16.
The first error that I get in my build report is:
moment.js.uncompressed.js:9: ERROR - Parse error. '}' expected
import { hooks as moment, setHookCallback } from './lib/utils/hooks';
1 error(s), 0 warning(s)
Done (compile time:0.114s)There are many other errors as well, all associated with the moment library. I took a cursory look at the library. It appears as thought it was written using ES6 syntax. Not sure if this a problem for the build system.
Anyone else having luck with 3.16 builds?
Rene Rubalcava
Lloyd Heberlie
