Problem Measurement Widget
4671
04-02-2015 02:01 AM
NadirHussain
Dear all
i add the measurement widget in my application.the code for this part is given below.
esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
             var pms = new PictureMarkerSymbol("Images/i_draw_point.png", 24, 24);
             pms.setOffset(9, 11);
             var sls = new SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT,new dojo.Color([255, 0, 0, 0.55]), 4);
             var measurement = new esri.dijit.Measurement({map: map,lineSymbol:sls,pointSymbol:pms}, dojo.byId('measurementDiv'));
             measurement.startup();
The code for  HTML part is given.
                <div   id="mapDiv" style="height:100%;width:75%; background-color:white;float:left; margin-right: 0px; margin-top: 0px;border-top:3px solid #00f">
                               <div id="HomeButton"></div>
                                <div style="position:absolute; right:400px; top:40px;background-color:White; z-Index:999;">
                                    <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
                                        <div id="measurementDiv"></div>
                                        <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
                                    </div>
                              </div>
                      </div>
              but my measurement not display whole as shown in attatched image.pls what can be the reason.
JakeSkinner
Esri Esteemed Contributor
Hi Nadir,
It may be helpful to post all of your code, or upload the HTML file you are working.
MuditAgarwal
Hi Nadir,
Please find below the working example of Measurement widget. It may help you.
JS Fiddle Link
Sand Box Link
Thanks
Mudit
