Problem for Operational Layer loaded before Basemap Layer
1209
01-30-2014 02:21 AM
ShaningYu
Honored Contributor
This is a continuation of my thread at http://forums.arcgis.com/threads/101693-Zoom-level?p=362198&posted=1#post362198.  In that thread, I reported the Zoom level in JS application.  Using Jeff's approach, I added the operation layer, which  is defined with deeper scale in ArcGIS Server, before I added another other layers.  The problem remained is that once a basemap is loaded, that operational layer becomes invisible.
However, in my SL application, it is not a problem.
Is there any way to solve it?  Thanks.
ShaningYu
Honored Contributor
Using the procedure below, the problem is solved:
1) Change esri.layers.ArcGISTiledMapServiceLayer to esri.layers.ArcGISDynamicMapServiceLayer for the basemap.
2) Set the basemap opacity: 0.5.
3) Load the operation layer that can scale deeper as the 1st layer.
ShaningYu
Honored Contributor
JeffPace
This is correct, and will allow you to scale deeper than lowest level (19) by rendering everything dynamically.
However, performance is SEVERELY impacting rendering a basemap dynamically.
I would recommend against it.
ShaningYu
Honored Contributor
Jeff:  Actually, it can zoom deeper than L19, and can go as deeper as that in ArcMap.  I added an opcity slider for the basemap: US Streets.  It looks fine.  But I can't use ESRI basemap gallery, as pointed out already.  Thanks anyway.
