Problem displaying a tile layer with a feature layer
3201
06-20-2016 04:32 AM
MohamedHamoud
I am facing a strange behavior using Java script API 4.0. I have two layers to display, one is a tile layer and the other one is a feature layer. When I add the tile layer at the bottom, then I can't zoom in to all levels, but when I add the tile layer at the top every thing goes well but of curse the feature layer will not be visible.
Below is the code that cause the problem:
var MyFeatureLayer = new FeatureLayer({
    url: "http://*******/MapServer"
var MyTileLayer = new TileLayer({
  var map = new Map({
  layers: [MyTileLayer, MyFeatureLayer]
If I changes the order when adding the layers it works, but the tile layer will hide the feature layer:
  var map = new Map({
      layers: [MyFeatureLayer, MyTileLayer]
Any Idea?
UndralBatsukh
Hi there,
You are running to this behavior because the LODs and the min/max scale values come from the 1st layer you add to the map.
MohamedHamoud
I modified the code to remove any scale restriction, but this didn't fix the issue:
 var view = new MapView({
container: "viewDiv",
map: map,
constraints: {
minScale: 0,
maxScale: 0
