Problem display with WMS and WMTS
1816
09-14-2022 01:50 AM
LionelGOUBET
Depending on the order of raster backgrounds specified for the map,
the WMTS service is not displayed when the first layer is the IGN WMS service.
Apparently the problem comes from the fact that the capabilities service returns the
<CRS>CRS:84</CRS> first but not 3857 but how to change it ?
My sample code for test (see join file wms_wmts_ign_arcgis.zip)
  // Add layers to array
      // esri first one => OK it works
      /*aLayers.push(esriLayer);
      aLayers.push(ignWmtsLayer);
      aLayers.push(ignWmsLayer);*/
      // wmts first one => OK it works
      /*aLayers.push(ignWmtsLayer);
      aLayers.push(esriLayer);*/
      // wms first one => NO it doesn't work => how change CRS WMS in spatialreferences ?
Thanks for your help
Tags (1)
JoelBennett
MVP Regular Contributor
The issue you're running into is the same underlying issue discussed here: the 3.x API can have problems with tiled layers when the first layer added to the map is not tiled.  The solution is to define the map's tiling info up front.
Try this instead, which would replace your current call to "require":
    require([
      "esri/map","esri/SpatialReference", "esri/geometry/Extent", "esri/layers/WMSLayer", "esri/layers/WMSLayerInfo", "esri/layers/WMTSLayer", "esri/layers/WMTSLayerInfo",
      "esri/config", "esri/layers/TileInfo", "esri/geometry/Point",
      "dojo/domReady!"
    ], function(
      Map, SpatialReference, Extent, WMSLayer,WMSLayerInfo, WMTSLayer, WMTSLayerInfo,
      esriConfig, TileInfo, Point
      var extent3857 = new Extent({
          xmin: 612056.7798435382,
          ymin: 5682778.707431033,
          xmax: 822811.5409472634,
          ymax: 5780363.363667572,
          spatialReference: { wkid: 102100, latestWkid: 3857 }
      var extent4326 = new Extent({
          xmin: 5.7238,
          ymin: 45.6390,
          xmax: 5.984802,
          ymax: 45.828799,
          spatialReference: { wkid: 4326 }
      esriConfig.defaults.io.proxyUrl = "/AP_voirie/web/kernel/proxy/proxy.ashx";
      map = new Map("map", {
        extent:extent3857,//pseudo mercator,
        zoom: 13
	  var tileInfo = new TileInfo({
		dpi: 96,
		height: 256,
		lods: [
				level: 0,
				resolution: 156543.033928,
				scale: 591657527.591555
				level: 1,
				resolution: 78271.5169639999,
				scale: 295828763.795777
				level: 2,
				resolution: 39135.7584820001,
				scale: 147914381.897889
				level: 3,
				resolution: 19567.8792409999,
				scale: 73957190.948944
				level: 4,
				resolution: 9783.93962049996,
				scale: 36978595.474472
				level: 5,
				resolution: 4891.96981024998,
				scale: 18489297.737236
				level: 6,
				resolution: 2445.98490512499,
				scale: 9244648.868618
				level: 7,
				resolution: 1222.99245256249,
				scale: 4622324.434309
				level: 8,
				resolution: 611.49622628138,
				scale: 2311162.217155
				level: 9,
				resolution: 305.748113140558,
				scale: 1155581.108577
				level: 10,
				resolution: 152.874056570411,
				scale: 577790.554289
				level: 11,
				resolution: 76.4370282850732,
				scale: 288895.277144
				level: 12,
				resolution: 38.2185141425366,
				scale: 144447.638572
				level: 13,
				resolution: 19.1092570712683,
				scale: 72223.819286
				level: 14,
				resolution: 9.55462853563415,
				scale: 36111.909643
				level: 15,
				resolution: 4.77731426794937,
				scale: 18055.954822
				level: 16,
				resolution: 2.38865713397468,
				scale: 9027.977411
				level: 17,
				resolution: 1.19432856685505,
				scale: 4513.988705
				level: 18,
				resolution: 0.59716428355981721,
				scale: 2256.994353
				level: 19,
				resolution: 0.29858214164761665,
				scale: 1128.4971760000001
				level: 20,
				resolution: 0.1492910708899543,
				scale: 564.248588
				level: 21,
				resolution: 0.0746455354449772,
				scale: 282.124294
				level: 22,
				resolution: 0.0373227677224886,
				scale: 141.062147
				level: 23,
				resolution: 0.0186613838612443,
				scale: 70.5310735
				level: 24,
				resolution: 0.0093306919306222,
				scale: 35.26553675
		origin: new Point(-20037508.342787, 20037508.342787, new SpatialReference(3857)),
		spatialReference: new SpatialReference(3857),
		width: 256
	  map._params.tileInfo = tileInfo;
	  map.__tileInfo = tileInfo;
      dojo.connect(map, "onLoad", function ()
        console.log("maponload");
        //ignWmsLayer.spatialReference = { wkid: 102100, latestWkid: 3857 }  ;
        //ignWmtsLayer.spatialReference = { wkid: 102100, latestWkid: 3857 }  ;
        //ignWmsLayer.spatialReferences[0] = 3857;
        console.log(ignWmsLayer.spatialReferences);
        console.log("spatialReference esriLayer  : " ,  esriLayer.spatialReference);
        console.log("spatialReference ignwms : " ,  ignWmsLayer.spatialReference);
        console.log("spatialReference ignWmtsLayer  : " , ignWmtsLayer.spatialReference);
      var aLayers = [];
      // ESRI basemaps
      var strEsriUrl = "https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer";
      esriLayer = new esri.layers.ArcGISTiledMapServiceLayer(strEsriUrl);
      // IGN basemaps
      // WMS
      // https://wxs.ign.fr/cartes/geoportail/r/wms?request=GetCapabilities&service=WMS
      // Premier systeme de coordonnées de référence : CRS:84 comment le changer au chargement
      var strIgnWmsUrl = "https://wxs.ign.fr/cartes/geoportail/r/wms";
      Test avec Layer info
      var WMSLayerInfo1 =  new esri.layers.WMSLayerInfo({
        title: 'SCANREG_PYR-JPEG_WLD_WM',
        spatialReferences : [3857]
      var resourcesInfo = {
          layerInfos: [WMSLayerInfo1],
          spatialReferences : [3857],
          extent: extent3857
      ignWmsLayer = new esri.layers.WMSLayer(strIgnWmsUrl, {
            format: "jpeg",
            minScale: 100000000,
            maxScale: 200,
            resourceInfo : resourcesInfo,
            visibleLayers: ["SCANREG_PYR-JPEG_WLD_WM"],
            transparent: true,
            id: "WMS ScanRegion"
              format: "jpeg",
              maxScale: 200,
              transparent: true,
      // WMTS
      // https://wxs.ign.fr/ortho/geoportail/wmts?request=GetCapabilities&service=WMTS&version=1.0.0
      var strIgnWmtsUrl = "https://wxs.ign.fr/ortho/geoportail/wmts";
      var layerInfo =  new esri.layers.WMTSLayerInfo({
              identifier: "ORTHOIMAGERY.ORTHOPHOTOS",
              tileMatrixSet: "PM",
              format: "jpeg"
      var ignOptions = {
              serviceMode: "KVP",
              maxScale: 200,
              layerInfo: layerInfo
      ignWmtsLayer = new esri.layers.WMTSLayer(strIgnWmtsUrl, ignOptions);
      // setVisibility first layer
      for (let index = 0; index < aLayers.length; index++) {
        let layer = aLayers[index];
        if (index == 0) layer.setVisibility(true);
        else layer.setVisibility(false);
      // Add basemaps layers
      map.addLayers(aLayers);
JoelBennett
    require([
      "dojo/domReady!"
    ], function(
          xmin: 5.7238,
          ymin: 45.6390,
          xmax: 5.984802,
          ymax: 45.828799,
        zoom: 13
		dpi: 96,
		height: 256,
		lods: [
				level: 0,
				level: 1,
				level: 2,
				level: 3,
				level: 4,
				level: 5,
				level: 6,
				level: 7,
				level: 8,
				level: 9,
				level: 10,
				level: 11,
				level: 12,
				level: 13,
				scale: 72223.819286
				level: 14,
				scale: 36111.909643
				level: 15,
				scale: 18055.954822
				level: 16,
				scale: 9027.977411
				level: 17,
				scale: 4513.988705
				level: 18,
				scale: 2256.994353
				level: 19,
				level: 20,
				scale: 564.248588
				level: 21,
				scale: 282.124294
				level: 22,
				scale: 141.062147
				level: 23,
				scale: 70.5310735
				level: 24,
				scale: 35.26553675
		width: 256
      var aLayers = [];
      // ESRI basemaps
      // IGN basemaps
      // WMS
          extent: extent3857
            format: "jpeg",
            maxScale: 200,
            transparent: true,
              format: "jpeg",
              maxScale: 200,
              transparent: true,
      // WMTS
              format: "jpeg"
      var ignOptions = {
              serviceMode: "KVP",
              maxScale: 200,
LionelGOUBET
OK thanks a lot ... it works 😁
I suppose you guess you found the tile values ​​with the properties "level" on https://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer
I can found the others values on wmts capabilities if I need  on element TileMatrixSet
sample : https://wxs.ign.fr/ortho/geoportail/wmts?request=GetCapabilities&service=WMTS&version=1.0.0;
this is the reason why it work with wmts at first.
However, this solution is not automatic...
