problem Directions use geocoding service (arcgis server 10.2)
2987
10-09-2015 05:00 AM
lasinh
i use The Directions widget   to calculate directions between two  input locations,  and adds a stop on each map click ( mapClickActive: true), but when i click on map then result in input is lat, long(coordinates);  how to get address to input parameter Directions widget when map click?
have services geocoding(on arcgis 10.2 server) allow get address when click on map ??
i use geocoding services on arcgis 10.2 server.
my code:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Directions Widget</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
      require([
       "esri/map", "esri/tasks/locator","esri/dijit/Directions", "esri/dijit/Search","esri/layers/FeatureLayer",
        "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
         Map, Locator, Directions, Search,FeatureLayer,
        parser
        parser.parse();
        //all requests to route.arcgis.com will proxy to the proxyUrl defined in this object.
         map = new Map("map", {
                zoom: 0,
                center: [396519, 1874207]
          var tiled = new esri.layers.ArcGISTiledMapServiceLayer("http://localhost:port/arcgis/rest/services/XH_150715/MapServer");
          map.addLayer(tiled);
          var tiled1 = new esri.layers.ArcGISTiledMapServiceLayer("http://localhost:port//arcgis/rest/services/TXH_150715/MapServer");
          map.addLayer(tiled1);
        var directions = new Directions({
          map: map,
          mapClickActive: true,
          routeTaskUrl: "http://localhost:port//arcgis/rest/services/Net/network011/NAServer/Route",
          geometryTaskUrl:  "http://localhoost:6080/arcgis/rest/services/Utilities/Geometry/GeometryServer",
          travelModesServiceUrl: "http://utility.arcgis.com/usrsvcs/servers/cdc3efd03ddd4721b99adce219629489/rest/services/World/Utili...",
          searchOptions: {
         sources: [
        locator: new Locator("http://localhost:port//arcgis/rest/services/ge/GEOCODING_SONHA_BH/GeocodeServer"),
        singleLineFieldName: "SingleLine",
         name: "Custom Geocoding Service",
         placeholder: "Search Geocoder",
         maxResults: 3,
         maxSuggestions: 20,
         enableSuggestions: true,
         minCharacters: 0
        },"dir");
        directions.startup();
    </script>
  </head>
  <body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'right'"
           style="width:250px;">
        <div id="dir"></div>
      </div>
      <div id="map"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
