Problem: custom LODS makes disappear basemap
1387
11-19-2012 11:19 AM
YvanBérard
Hi all,
since i used custom LODS, my basemap won't show.
Why?
I'm using the basemap World_Imagery from ArcGIS Online.
Thank's for your help.
var basemapUrl = "http://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer"; var lods = [ {  "level": 0,  "resolution": 26.458386250105836,  "scale": 100000 }, {  "level": 1,  "resolution": 13.229193125052918,  "scale": 50000 }, {  "level": 2,  "resolution": 5.291677250021167,  "scale": 20000 }, {  "level": 3,  "resolution": 2.6458386250105836,  "scale": 10000 }, {  "level": 4,  "resolution": 1.3229193125052918,  "scale": 5000 }, {  "level": 5,  "resolution": 0.6614596562526459,  "scale": 2500 }, {  "level": 6,  "resolution": 0.26458386250105836,  "scale": 1000 }, {  "level": 7,  "resolution": 0.19843789687579377,  "scale": 750 }, {  "level": 8,  "resolution": 0.13229193125052918,  "scale": 500 }];  var initialExtent = new esri.geometry.Extent({"xmin":-8034661,"ymin":5652797,"xmax":-8004182,"ymax":5670187,"spatialReference":{"wkid":102100}});            map = new esri.Map("map", {  extent: initialExtent,  logo: true,  lods: lods });
JeffPace
No.  Its a cached service which means the tiles are pre-generated.  No tiles exist at your defined scales
You either need to
1. Create your own basemap
2. Access the basemap dynamic (not sure you can do this)
3. Use the existing LODS.
JeffPace
The AGO basemap is cached.  You have to match your LODS to the services LODs
YvanBérard
so i won't be able to use it if i still use my custom LODS?
JeffPace
You either need to
