Problem converting projected coordinates to webmercator
3180
08-22-2012 02:45 AM
ChristianLindholm
I'm having a problem converting my coordinates in the Finnish KKJ2 coordinate system (i.e. Finland_Zone_2, wkid 2392) to webmercator in order to plot points on my map.
I am trying to do this with the code
esri.geometry.geographicToWebMercator(new esri.geometry.Point(east, north, new esri.SpatialReference(2392)))
No matter what spatial reference I put in the code, it appears that arcgis assumes the coordinates are given in WGS84. It does not matter what wkid i put in my code, my points end up on the exact same location on the map regardless of the wkid.
Where should I start looking for a solution?
BR
-Christian
DavideLimosani
JohnnyPenet
Hi Christian,
I am not sure there is an easy way in Javascript for converting local geographic coordinates into projected coordinates. Having problems of converting WGS84 to Lambert 72 (31370), I wrote a number of javascript methods that did the job. One of the methods was the conversion between geographic and projected coordinates for Lambert 72. I think you will need something simular.
After some research, I used the conic conformal 2SP (Belgium) method, you will need 'JHS formulas' that can be found in the document http://www.epsg.org/guides/docs/G7-2.pdf
You can find a lot of documentation and code on a blog I wrote concerning conversions of projections in Javascript. First document is about the architecture. Second document contains the code. I hope the documents are easy readable.
http://jpenet.blogspot.be/2012/08/transformation-between-datums-in.html
Johnny
ChristianLindholm
Thanks for the reply. I was hoping for a more ready built solution 🙂
I managed to use some of the examples available on the ArcGIS site in order to convert my coordinates.
-Christian
DavideLimosani
PaulLohr
Is it possible to output coordinates other than Web Mercator or WGS 1984 latitude / longitude with the Javascript API, not using a geometry service? esri/geometry/webMercatorUtils offers the Web Mercator and WGS 1984 conversions. I am interested in outputting coordinates to a projected state plane system. I briefly looked over the documentation but did not find an answer.
Here is the documentation for the webMercatorUtils (version 3.x)
esri/geometry/webMercatorUtils | API Reference | ArcGIS API for JavaScript 3.22
Thank you for any help,
Paul Lohr
Paul Lohr
Lohr Geospatial Services, Inc.
