PrintTask does not print the graphics in the proper order
2514
6
09-11-2013 09:07 AM
JasonZou
I've used the PrintTask to perform the print job. It performs well until I add some graphics, and found out that the points and texts ar printed underneath the polygons even if the points and texts are drawn on top of the polygons. Please see the attached images. The first image shows the partial screenshot from the app. One point sits on top of the circle, and another one sits under the circle. The second image is the printout image. Both points sit underneath the circles. Can ESRI look into this issue?
[ATTACH=CONFIG]27358[/ATTACH]              [ATTACH=CONFIG]27359[/ATTACH]
by Anonymous User
Not applicable
Original User: vinaybansal
Are you adding graphics to map graphics or in a separate graphic layers.
Add points and polygon in a separate graphics layer and then take printout
JasonZou
Thanks Vinay for quick reply. These graphics are added to the same graphics layer created other than map.graphics. You can reproduce the issue using this sample.
by Anonymous User
Not applicable
By separate graphic layer I mean a separate graphics layer for Points and Polygons. And ordering the layer such that Point graphics is on top of polygons......
JasonZou
That might work. I will test it out though. But I really hate to create one graphics layer for polygons and maybe polylines, and another one for points and texts just to make it work for print. It sounds very awkward.
EDIT: just tested it out, and Vinay's workaround does work. Thanks, Vinay. But I do like to see that ESRI can provide a permanent solution for this issue.
by Anonymous User
Not applicable
Yes it looks awkward.....But if you look into the printtask.js in ArcGIS Javascript API : This is what ESRI does for map graphics and single graphic layer graphics....
Creates layers internally for polygon,polyline,point and multipoint.....and then adds point layer first, then polyline, then polygon and then multipoint to the featurecollection arrays.....
_
createFeatureCollection: function (_2f) {
            var _30 = new this._polygonLayer();
            var _31 = new this._polylineLayer();
            var _32 = new this._pointLayer();
            var _33 = new this._multipointLayer();
            if (_2f.declaredClass === "esri.layers.FeatureLayer") {
                _30.layerDefinition.name = _31.layerDefinition.name = _32.layerDefinition.name = _33.layerDefinition.name = _2f.name || _2f.id;
            if (_2f.renderer && !_2.isFunction(_2f.renderer.attributeField)) {
                _30.layerDefinition.drawingInfo.renderer = _2f.renderer.toJson();
                _31.layerDefinition.drawingInfo.renderer = _2f.renderer.toJson();
                _32.layerDefinition.drawingInfo.renderer = _2f.renderer.toJson();
                _33.layerDefinition.drawingInfo.renderer = _2f.renderer.toJson();
            } else {
                delete _30.layerDefinition.drawingInfo;
                delete _31.layerDefinition.drawingInfo;
                delete _32.layerDefinition.drawingInfo;
                delete _33.layerDefinition.drawingInfo;
            } if (_2f.fields) {
                _30.layerDefinition.fields = _2f.fields;
                _31.layerDefinition.fields = _2f.fields;
                _32.layerDefinition.fields = _2f.fields;
                _33.layerDefinition.fields = _2f.fields;
            var _34, i;
            for (i = 0; i < _2f.graphics.length; i++) {
                var g = _2f.graphics;
                if (g.visible === false || !g.geometry) {
                    continue;
                _34 = g.toJson();
                if (_34.symbol && _34.symbol.outline && _34.symbol.outline.color && _34.symbol.outline.color[3]) {
                    _34.symbol.outline.color[3] = 255;
                if (_2f.renderer && _2.isFunction(_2f.renderer.attributeField) && !_34.symbol) {
                    _34.symbol = _2f.renderer.getSymbol(g) ? _2f.renderer.getSymbol(g).toJson() : _34.symbol;
                switch (g.geometry.type) {
                case "polygon":
                    _30.featureSet.features.push(_34);
                    break;
                case "polyline":
                    _31.featureSet.features.push(_34);
                    break;
                case "point":
                    _32.featureSet.features.push(_34);
                    break;
                case "multipoint":
                    _33.featureSet.features.push(_34);
                    break;
            var _35 = [];
            if (_32.featureSet.features.length > 0) {
                _35.push(_32);
            if (_31.featureSet.features.length > 0) {
                _35.push(_31);
            if (_30.featureSet.features.length > 0) {
                _35.push(_30);
            if (_33.featureSet.features.length > 0) {
                _35.push(_33);
            var _36 = {
                layers: _35
            var _37 = {
                opacity: _2f.opacity,
                minScale: _2f.minScale || 0,
                maxScale: _2f.maxScale || 0,
                featureCollection: _36
            return _37;
If seperate graphics layers are created then they are added in the order they are created........
JasonZou
Thanks for pointing me to the function. It seems the point graphics are put underneath the polygons by design. Is there any specific reason for doing that? I think it is against the way people normally do.
Matter of fact, people expect to see the graphics shown on the printout page the same order as shown on the map. With that being said, personally I think it is a bad idea to re-group the graphics out of a graphics layer based on the spatial type because more than likely it will break the order shown on the map anyway.
