Printing text from LabelLayer
1075
06-18-2014 09:16 PM
DuncanNisbett
I have a map where I'm utilizing the LabelLayer to handle labeling the graphics for me. When I setup the print task and execute it, I notice that the LabelLayer data isn't included in the posted information. I create the labellayer and add it as a layer to my map. Any suggestions on how to get the TextSymbols from a label layer to show up?
MuditAgarwal
Not sure about label layer but you can achieve the functionality by adding a separate graphic layer for labels (text symbols) instead of label layer. Here is the link for working example.
DuncanNisbett
I appreciate the recommendation. It was a good starting point for the solution I came up with. Unfortunately I can't post the actual solution as it's tied up in a much, much larger application.
