Printask printtemplate legend issue
2811
10-10-2016 12:49 AM
ThaboGilbert
I need to ask , how to check the passed legend layer info( json) into the printtemplate before printing.
Please geo programmers i need your assistance.
ThaboGilbert
RobertScheitlin__GISP
Thabo,
   Are you using the Print Dijit or just some custom code that uses the PrintTask?
ThaboGilbert
I am using Print task but not single function which runs on the click
attached is the code :
function printMap() {
console.log('Global Render
info')
console.log(global_renderer);
layer.setRenderer(global_renderer);
layer.redraw();
//createLegend(rendering.featureMap.fields[0]);
var legendLayer = new
LegendLayer();// Get the legend Layers
legendLayer.layerId =
layer.id;
console.log('legend Layer
for Print');
console.log(layer);
var printMap = new
esri.tasks.PrintTask("http://statscenprod:6080/arcgis/rest/services/ExportWebMap9/GPServer/Export%20Web%20Map");
var params = new
esri.tasks.PrintParameters();
var template = new
esri.tasks.PrintTemplate();
var txtmetadata =
document.getElementById("metadata").innerHTML;
var len = 35;
var curr = len;
var prev = 0;
alert(txtmetadata);
output = [];
var textmetaadat;
if (txtmetadata.length >
35)
while
(txtmetadata[curr]) {
if (
txtmetadata[curr++] == ' ') {
output.push(txtmetadata.substring(prev, curr).trim());
prev
= curr;
curr
+= len;
output.push(txtmetadata.substr(prev).trim());
var joinedtxt =
output.join('\n')
alert(joinedtxt);
textmetaadat =
"Metadata : " + "\n" + joinedtxt;
else
textmetaadat =
"Metadata : " + "\n" + document.getElementById("metadata").innerHTML;
template.exportOptions = ;
template.format = "pdf";
template.layout = "Letter
ANSI A Landscape6";
console.log(legendLayer);
template.preserveScale =
true;
template.showAttribution =
false;
template.layoutOptions =
params.map = map;
params.template = template;
printMap.execute(params,
printResult).then(function(resolvedVal){
console.log(resolvedVal);
// Logs the value the promise resolves to
function printResult(result) {
var time = new Date();
console.log(time.getTime())
window.open(result.url +=
"?Atlastimets=" + time.getTime());
console.log('check the layer
after printing')
console.log(layer);
$('#btn').click(function () {
printMap();
Regards
Thabo Gilbert Mojahi
Cell : 0713208732
Fax : 086 601 8766
Tel(office) : 012 310 6397
If people do not believe that mathematics is simple, it is only because
they do not realize how complicated life is. ~John Louis von Neumann
>>> "Robert Scheitlin, GISP" <[email protected]> 10/10/2016 16:38 >>>
GeoNet
( https://community.esri.com/?et=watches.email.thread)
Re: Printask printtemplate legend issuereply from Robert Scheitlin,
GISP
( https://community.esri.com/people/rscheitlin?et=watches.email.thread)
in ArcGIS API for JavaScript - View the full discussion
https://community.esri.com/message/639938-re-printask-printtemplate-legend-issue?commentID=639938&et=watches.email.thread#comment-639938)
Thabo,
PrintTask?
Reply to this message by replying to this email, or go to the message
on GeoNet
Start a new discussion in ArcGIS API for JavaScript by email
mailto:discussions-community-developers-webdevelopers-arcgisapifor[email protected])
or at GeoNet
https://community.esri.com/choose-container.jspa?contentType=1&containerType=14&container=2128&et=watches.email.thread)
Following Re: Printask printtemplate legend issue
in these streams: Inbox
This email was sent by GeoNet because you are a registered user.
You may unsubscribe
https://community.esri.com/unsubscribe.jspa?email=thabomoj%40statssa.gov.za&token=8cc2f7c722630dbf4d0b040099a8f18de596fb44255fed8a1746a394189b9352)
instantly from GeoNet, or adjust email frequency in your email
preferences
( https://community.esri.com/user-preferences!input.jspa)
ThaboGilbert
I  needed to check the layer which the printtemplate receives so as to see if I am sending the right Layer.
However there is a problem with printing when I am rendering a field with ClassBreaksRenderer the legend renders perfectly with print legend , however when I am rendering I am rendering another field the sample attached
ThaboGilbert
in order to check the layer before printing I found this URL it has the answer:
How to customize the ArcGIS print legend text using javascript - Geographic Information Systems Stac...
