Print Widget - Custom Text Elements Issues on >4.24
3371
03-28-2023 08:49 AM
AnisHalabi
An issue seems to have risen in the latest JS-API versions. This issue wasn't present in V4.23, and has started in V4.24.
Custom Text Elements are not being loaded from the Custom Template and not populated in the Print Widget advanced options. Subsequently, the custom text elements are also not sent to the print service. I have validated the naming of the layouts info service "Get Layout Templates Info" as the documentation states.
Yet, as described above, this logic stops working as of 4.24 (also tried 4.25, and 4.26 AMD). I also didn't find any specific change in the changelog which might be related to this feature, except for the north arrow for print widget.
See attached, the print widget on 4.23 and 4.26 to compare.
Lerman
Hi, it is bug.
Bug number: BUG-000150859
Synopsis: Custom layout in printing widget does not appear in the ArcGIS API for JavaScript 4.24
Lerman
Hi, it is bug.
LuizaCintra_Fernandes
When these is going to be fixed?
BenClark
Is this bug still present in 11.3? I'm experiencing similar behavior and am trying to figure out why.
