Print Template Dijit - Just two options to print
1379
01-23-2014 07:57 AM
ionarawilson1
Is it possible to change the print template dijit options, for example not to have so many options (delete a few) and also to change what they are called, for example, instead of "A4 Landscape" I would have only Landscape. I would like to have only two options: Landscape and Portrait and they would be of size A4. Thank you
https://developers.arcgis.com/en/javascript/jssamples/widget_print_esri_request.html
JonathanUihlein
Absolutely.
From the sample you posted, you can change the names by changing attributes for:
layoutTemplate[0].choiceList
or
templateNames
For example:
layoutTemplate[0].choiceList[0] = "Landscape";
OR
templateNames[0] = "Landscape";
Hope this helps.
ionarawilson1
Thank you Jonathan! It worked!!! I also changed the code to remove the other options
    layoutTemplate[0].choiceList.splice(2, 7)
Thank  you!!!
JonathanUihlein
Awesome!! I'm glad it works.
Let me know if any issues arise 😃
ionarawilson1
Actually the changes are made visually, but I click to Print, the printing does not work. It shows "Printing" for a millisecond then goes back to "Print" and it never shows a "Printout". I am going to try on the sandbox to see what happens
