Print Task produces errors
3767
06-05-2014 06:34 AM
SaqibAmin2
The following is the JavaScript function:
function Print() {
      var app = {};
      require([
        "esri/map", "esri/layers/FeatureLayer", "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/dijit/Print", "esri/tasks/PrintTemplate",
        "esri/request", "esri/config",
        "dojo/_base/array", "dojo/dom", /*"dojo/parser",*/
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, FeatureLayer, ArcGISDynamicMapServiceLayer,
        Print, PrintTemplate,
        esriRequest, esriConfig,
        arrayUtils, dom/*, parser*/
        //parser.parse();
  app.printUrl = "http://www.mapping2.cityoflondon.gov.uk/arcgis/rest/services/Printing/ExportWebMap/GPServer/Export%20Web%20Map";
  esriConfig.defaults.io.proxyUrl = "http://vmgisapp02/proxy/proxy.ashx";
   app.map = map;
 app.map = new esri.Map("map");
 var permitUrl = "http://vmgisapp03/arcgis/rest/services/Test4YellowLines/MapServer/0";
        var poolFeatureLayer = new FeatureLayer(permitUrl, {
          "mode": FeatureLayer.MODE_SNAPSHOT
        app.map.addLayer(poolFeatureLayer);
        // get print templates from the export web map task
        var printInfo = esriRequest({
          "url": app.printUrl,
          "content": { "f": "json" }
        printInfo.then(handlePrintInfo, handleError);
        function handlePrintInfo(resp) {
          var layoutTemplate, templateNames, mapOnlyIndex, templates;
          layoutTemplate = arrayUtils.filter(resp.parameters, function(param, idx) {
            return param.name === "Layout_Template";
          if ( layoutTemplate.length == 0 ) {
            //alert("print service parameters name for templates must be \"Layout_Template\"");
            return;
          templateNames = layoutTemplate[0].choiceList;
          // remove the MAP_ONLY template then add it to the end of the list of templates
          mapOnlyIndex = arrayUtils.indexOf(templateNames, "MAP_ONLY");
          if ( mapOnlyIndex > -1 ) {
            var mapOnly = templateNames.splice(mapOnlyIndex, mapOnlyIndex + 1)[0];
            templateNames.push(mapOnly);
          // create a print template for each choice
          templates = arrayUtils.map(templateNames, function(ch) {
            var plate = new PrintTemplate();
            plate.layout = plate.label = ch;
            plate.format = "PDF";
            plate.layoutOptions = {
              "authorText": "Made by:  Esri's JS API Team",
              "copyrightText": "<copyright info here>",
              "legendLayers": [],
              "titleText": "Pool Permits",
              "scalebarUnit": "Miles"
            return plate;
          app.printer = new Print({
            "map": app.map,
            "templates": templates,
            url: app.printUrl
          }, dom.byId("print_button"));
          app.printer.startup();
        function handleError(err) {
          alert("Something broke: ", err);
When this function is outputted on a html map page, I get Cross Origin errors, these don't stop the code from working??
( Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at http://vmgisapp03/arcgis/rest/services/Printing/ExportWebMap/GPServer/Export%20Web%20Map/execute. This can be fixed by moving the resource to the same domain or enabling CORS. )
The following error is more worrying:
POST http://www.mapping2.cityoflondon.gov.uk/arcgis/r...ExportWebMap/GPServer/Export%20Web%20Map/execute
Aborted
  60s
init.js (line 157)
RequestTimeoutError: Timeout exceeded
...g"],function(b){return function(m,e,p,n){p=p||Error;var k=function(b){if(p===Err...
I have tested the line.... "app.map = map;"
When I comment out "app.map = map;" and uncomment the code block below it, everything works fine.
The line "app.map=map;" is taking the existing map object from another JS file elsewhere.
It would be great to hear your thoughts.
Saqib.
SaqibAmin2
I have realised all my code is "correct", the problem it seems is not in my code but in which basemap I am using.
We are using Bing basemapping, when I switch this off, the printing functions correctly.
Is there anything I can do to allow Bing basemaps to print?
MuditAgarwal
Hi Saqib,
Please try adding Bing base map as separate base map layer instead of passing map object with base map.
Regards
Mudit
SaqibAmin2
Hi Mudit,
I've added the Bing map as a separate basemap layer and I get the following message in console:
"NetworkError: 500 ConnectFailure - http://vmgisapp02/proxy/proxy.ashx?http://dev.virtualearth.net/REST/v1/Imagery/Metadata/road?key=AnH..."
I get the same error when I put the double url in my browser, in this case I checked my proxy.config file and the virtual earth url is already present "http://dev.virtualearth.net/REST/"
The problem is obviously Bing isn't allowed through proxy. I also added the following line "esri.config.defaults.io.alwaysUseProxy = true;" to the code, setting the variable to false ends up giving me a CORS error.
Regards,
Saqib.
