Print service/widget/viewModel issue
720
05-07-2025 03:22 AM
ChristopheSuter
I am trying to print a map that contains clustered points rendered using a pie chart.
Using the SDK's print widget the generated PDF does not render the points using clusters and piecharts but as points (cluster centers ?) with unique value rendering.
See CodePen https://codepen.io/christophesuter/pen/wBBXQmw
Same thing using esri/rest/print:
Same thing when using rest/print https://codepen.io/christophesuter/pen/xbbzmBo
Anyone knows if this a known limitation of the printService ?
Noah-Sager
Hi @ChristopheSuter, thanks for reporting this issue here. This is not the expected output. Will investigate and respond back.
Update: we've identified the issue and we'll work to get this fixed for an upcoming release.
Noah-Sager
