Print Secured Services using IWA
648
11-17-2025 09:37 AM
vijaybadugu
I am using ArcGIS JavaScript SDK to export the map to PDF. I do not have any issues the service shared with everyone, when i tried to share it to organization, it is throwing an error " Failed to create layer from service ".
Print service is also shared with organization. is there a way to pass the credentials or token ?
SteveCole
Honored Contributor
One thing to check out is on the SDE side of things. I was getting the same error through an Experience Builder app (thread here) and, through some exploration, we discovered that the layer that would throw the error did not have the same accounts listed on SDE's Manage->Privileges compared to other layers which did print fine. Again, not saying that this is your issue but it's something to check.
Steve
vijaybadugu
The issue is with the secured service URL inside the WebMap JSON. The token is not being appended. How can I intercept or modify the WebMap JSON before printing so that I can add the token?
