Print Dijit Example not working in IE 8
2521
8
05-20-2013 01:31 PM
TracySchloss
Honored Contributor
I have a basic print example  based on http://help.arcgis.com/en/webapi/javascript/arcgis/jssamples/widget_print_esri_request.html, but I have changed out the webmap for a standard JS map with arcdynamicservicelayers etc.   This works just fine in Firefox.  When I try the sample code in IE 8, it doesn't look to load the esri.dijit.Print I created.  Instead, looking at the IE Developers Tools, I'm getting errors for 'Object doesn't support this property or method' .
The Print button I expect to see never loads and neither does my map.  I've played with a couple of different version of the API, but that doesn't seem to help.
This must work in IE.  Maybe it's something small I just haven't spotted yet?
<!DOCTYPE html> <html>   <head>     <meta http-equiv="Content-Type" content="text/html; charset=utf-8">     <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9">      <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">     <title>Print Digit Sample</title>          <link type="text/css" rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/claro/claro.css">      <link type="text/css" rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css">      <style>       html, body { height: 100%; width: 100%; margin: 0; padding: 0; }       h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; padding: 0 0 5px 0; text-align: center; }        #map{ margin: 0; padding: 0; }       #printDiag {         background: #fff;         border: solid;         border-width: 1px;         color: #000;         font-family: arial;         height: auto;         right: 30px;         top: 30px;         margin: 5px;         padding: 10px;         position: absolute;         width: 300px;         z-index: 40;        #note { font-size: 80%; font-weight: 700; padding: 0 0 10px 0; }       #info { padding: 10px 0 0 0; }     </style>           <script type="text/javascript">             var dojoConfig = {                 parseOnLoad: true             };         </script>         <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.2">         </script>     <script>       dojo.require("dijit.layout.BorderContainer");       dojo.require("dijit.layout.ContentPane");       dojo.require("esri.arcgis.utils");       dojo.require("esri.dijit.Print");        var pathName = "https://myserver.gov";       var printUrl; printUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task";         function init(){                  esri.config.defaults.io.proxyUrl = "proxy/proxy.ashx";         spatialReference = new esri.SpatialReference({             wkid: 102100         });         startExtent = new esri.geometry.Extent(-10723197, 4186914, -9829190, 4992866, spatialReference);         map = new esri.Map("map", {             extent: startExtent });                  countyLayer = new esri.layers.ArcGISDynamicMapServiceLayer(pathName + "/ArcGIS/rest/services/BaseMap/county_simple/MapServer", {             id: "countyLayer"         });         map.addLayer(countyLayer);         createPrintDijit("This is my Title");     }       function createPrintDijit(printTitle) {         var layoutTemplate, templateNames, mapOnlyIndex, templates;                  // create an array of objects that will be used to create print templates         var layouts = [           {              "name": "Letter ANSI A Landscape",              "label": "Landscape - PDF",              "format": "pdf",              "options": {                "legendLayers": [], // empty array means no legend               "scalebarUnit": "Miles",               "titleText": printTitle ,               "copyrightText": "Missouri Office of Geospatial Information"                            }           }, {             "name": "Letter ANSI A Portrait",              "label": "Portrait - PDF",              "format": "pdf",              "options":  {                "legendLayers": [],               "scaleBarUnit": "Miles",               "titleText": printTitle ,               "copyrightText": "Missouri Office of Geospatial Information"             }           }         ];                  // create the print templates, could also use dojo.map         templates = [];         dojo.forEach(layouts, function(lo) {           var t = new esri.tasks.PrintTemplate();           t.layout = lo.name;           t.label = lo.label;           t.format = lo.format;           t.layoutOptions = lo.options;           templates.push(t);         });          var printer = new esri.dijit.Print({           "map": map,           "templates": templates,           url: printUrl         }, dojo.byId("print_button"));                  printer.startup();       }        dojo.ready(init);     </script>   </head>     <body class="claro">     <div data-dojo-type="dijit.layout.BorderContainer"          data-dojo-props="design:'headline',gutters:false"          style="width: 100%; height: 100%; margin: 0;">       <div id="map"            data-dojo-type="dijit.layout.ContentPane"            data-dojo-props="region:'center'">          <div id="printDiag" >           <h3>            Creating Map Output           </h3>           <div id="info">             <div id="note">               To Use:  Click the print button to choose either Landscape or Portrait format.                <br><br>Once your PDF is generated, the print button will change link that says Printout.               Click it to view your PDF.             </div>                          <!-- that will be used for the print dijit -->             <div id="print_button" ></div>           </div>         </div>       </div>     </div>   </body>  </html>
KellyHutchins
Esri Notable Contributor
Ran a quick test on your code in IE8 and it fails because you don't declare the map using var. Try updating your code to be:
var map = ....
Tools like JSHint or JSLint can make finding these tiny little issues like missing variable declaration, trailing commas and missing semicolons much easier.
Kelly
VinayBansal
Hi Tracy,
Just try it in Google Chrome and check javascript console. It is giving XMLHTTPRequest Error saying Origin is null, but when trying with version 3.4. its working fine. If you are using services from ArcGIS 10.1 then just try replacing 3.2 with 3.4 and let me know.
TracySchloss
Honored Contributor
No, that didn't make any difference.  I have to have a printing solution that works in IE.  It is the state standard and users are rarely allowed to download and install any other browsers.  I have other browsers for myself, but I'm in IT.  I have to code to the lowest level of browser, which I think is still IE 7.
derekswingley1
The sample works in IE8. What's different between the sample code and your code?
One thing to look into is mixing https and http URLs. IE might be blocking request to some URLS based on your its security settings.
KellyHutchins
var map = ....
Kelly
YungKaiChin
I just viewed the sample on IE8 , and the Print dropdown button isn't displayed.
In the developer tools, it simply says, "LOG: Something broke: [object Error]".
derekswingley1
Are you viewing the sample on help.arcgis.com or developers.arcgis.com? Using the sample on developers.arcgis.com works and is what you should be using.
YungKaiChin
I see. I didn't know samples were not the same. Thanks.
TracySchloss
Honored Contributor
Thanks for the extra pair of eyes!  There are so many little things that aren't supported in IE 8 that I assumed I wasn't going to be able to use this as a print option.   I didn't notice the missing 'var' when I switch from a webmap to a basic locally hosted map and set of services.
