Prepopulated dropdown by query select value onchange
4287
11-10-2015 09:08 AM
AlexGole
Hi all, I made a dropdown that queries some attributes by "county" and returns results in a dropdown. Now I need to enable the user to select values onchange  or current from this prepoulated dropdown. I was able to get the first value but not the other values. Any ideas?
variable that stores the select value
 var pickerValues;
Queries for drop down:
//Select values from Alameda only - onload
                         var queryTask = new QueryTask("http://webgisdevint1/arcgis/rest/services/ResourceMgmt/WatershedMapper10_2/MapServer/5");
                         var query = new Query();
                         query.returnGeometry = false;
                         query.outFields = ["CALWNUM"];
                         query.where = "County = 'Alameda'";
                         queryTask.execute(query, function (results) {
                             //parse results and add to autocomplete widget
                             $.each(results.features, function (index, value) {
                                 $('#selectpickerValues').append($('<option>', {
                                     value: value,
                                     text: value.attributes.CALWNUM
                         //Query Planning Watershed
                         $("#selectpickerCounty").change(function () {
                             $('#selectpickerValues').empty();
                             query.where = "County='" + pickerCounty + "'";
                                         value: value.attributes.CALWNUM,
                                     pickerValues = value.attributes.CALWNUM;
Drop down:
<select id="selectpickerValues" class="form-control"></select>
Tags (3)
AlexGole
nevermind this worked:
$(document.body).on('change', "#selectpickerValues", function (e) {
                                     //doStuff
                                     pickerValues = $("#selectpickerValues option:selected").val();
AlexGole
                                     //doStuff
