prepare url
4829
04-23-2016 10:27 AM
CloudingSoft
Hello
I'm working with "Vehicle Routing Problem service"
http://resources.arcgis.com/en/help/arcgis-rest-api/#/Vehicle_Routing_Problem_service/02r3000000n400...
y no puedo reproducir el ejemplo PHP  de esta manera: "Servicing a set of orders with a fleet of vehicles"
$token = "my_token";
$jsonData  = '&orders={"features":[{"geometry":{"x":-122.51,"y":37.7724},"attributes":{"DeliveryQuantities":1706,"Name":"Store_1","ServiceTime":25,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}},{"geometry":{"x":-122.4889,"y":37.7538},"attributes":{"DeliveryQuantities":1533,"Name":"Store_2","ServiceTime":23,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}},{"geometry":{"x":-122.4649,"y":37.7747},"attributes":{"DeliveryQuantities":1580,"Name":"Store_3","ServiceTime":24,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}},{"geometry":{"x":-122.4739,"y":37.7432},"attributes":{"DeliveryQuantities":1289,"Name":"Store_4","ServiceTime":20,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}},{"geometry":{"x":-122.4493,"y":37.7315},"attributes":{"DeliveryQuantities":1302,"Name":"Store_5","ServiceTime":21,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}},{"geometry":{"x":-122.4917,"y":37.6493},"attributes":{"DeliveryQuantities":1775,"Name":"Store_6","ServiceTime":26,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}},{"geometry":{"x":-122.4832,"y":37.7012},"attributes":{"DeliveryQuantities":1014,"Name":"Store_7","ServiceTime":17,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}},{"geometry":{"x":-122.5301,"y":37.8935},"attributes":{"DeliveryQuantities":1761,"Name":"Store_8","ServiceTime":26,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}},{"geometry":{"x":-122.2875,"y":37.8909},"attributes":{"DeliveryQuantities":1815,"Name":"Store_9","ServiceTime":27,"TimeWindowStart1":1355245200000,"TimeWindowEnd1":1355274000000,"MaxViolationTime1":0}}]}';
$jsonData .= '&depots={"features":[{"geometry":{"x":-122.3943,"y":37.7967},"attributes":{"Name":"San Francisco","TimeWindowStart1":1355241600000,"TimeWindowEnd1":1355274000000}}]}';
$jsonData .= '&routes={"features":[{"attributes":{"Name":"Truck_1","StartDepotName":"San Francisco","EndDepotName":"San Francisco","StartDepotServiceTime":60,"EarliestStartTime":1355241600000,"LatestStartTime":1355241600000,"Capacities":"15000","CostPerUnitTime":0.2,"CostPerUnitDistance":1.5,"MaxOrderCount":2,"MaxTotalTime":360,"MaxTotalTravelTime":120,"MaxTotalDistance":80}},{"attributes":{"Name":"Truck_2","StartDepotName":"San Francisco","EndDepotName":"San Francisco","StartDepotServiceTime":60,"EarliestStartTime":1355241600000,"LatestStartTime":1355241600000,"Capacities":"15000","CostPerUnitTime":0.2,"CostPerUnitDistance":1.5,"MaxOrderCount":2,"MaxTotalTime":360,"MaxTotalTravelTime":120,"MaxTotalDistance":80}},{"attributes":{"Name":"Truck_3","StartDepotName":"San Francisco","EndDepotName":"San Francisco","StartDepotServiceTime":60,"EarliestStartTime":1355241600000,"LatestStartTime":1355241600000,"Capacities":"15000","CostPerUnitTime":0.2,"CostPerUnitDistance":1.5,"MaxOrderCount":2,"MaxTotalTime":360,"MaxTotalTravelTime":120,"MaxTotalDistance":80}}]}';
$url = 'https://logistics.arcgis.com/arcgis/rest/services/World/VehicleRoutingProblem/GPServer/SolveVehicleR...' . $jsonData;
$app_info = file_get_contents($url);
echo '<pre>';
var_dump($app_info); //RETURN FALSE
echo '</pre>';
this return Warning: file_get_contents(https://logistics.arcgis.com/arcgis/rest/services/World/VehicleRoutingProblem/GPServer/SolveVehicleR.......
RobertScheitlin__GISP
Fabien,
  I am not sure what the questions is here or where to move this question as right now you have it in the GeoNet community space. I think this belongs in the JavaScript space but I am really not sure because I don't understand the question.
CloudingSoft
hello, what I want is to send the url with php with the necessary information to get the result in json:
see the item:
Request URL to submit the job
ArcGIS REST API
this is my code, you do not have to do with javascript.
$token='my token';
$jsonData='other json data , view example';
echo '<pre>';
var_dump($app_info); //RETURN FALSE!!!
echo '</pre>';
but if income is generated with php url in Chrome gives me the correct json:
{"jobId":"jb0a050c89eed48d39f5f9dda89034935","jobStatus":"esriJobSubmitted"}
Fabien,
OK I guess this question belongs in the general developer space then. I have no experience with this type of question so maybe someone there will help. Placing your question in the correct GeoNet space will greatly help you get your question answered.
CloudingSoft
ok, and recommended me to take complete example of this section? ArcGIS REST API
I did it using only a browser to, but I need to do it from the server with php
