Portal.queryItems callback function execution timing
3013
05-11-2016 06:33 AM
NartTamash
Hi all,
I've got the following scenario...I'm querying my local Portal for certain items and then I am processing them using a callback function, as soon as the query returns them.
globalVariable
     function doSomeOtherStuff() {
          //do some other stuff
          //requires the updated globalVariable
     Portal.queryItems(params).then(processItems)
     doSomeOtherStuff();
     function processItems(items) {
          //do something
          //update globalVariable
Giving this is an async call, other things (i.e. doSomeOtherStuff()) carry on while the query is finalised and the items processed.
How can I wait for the processItems() to complete before doing anything else (so a synchronous operation in a sense)?
The processItems function updates a global variable that I need to use in doSomeOtherStuff() and carry on with the logic. I can't execute doSomeOtherStuff() within processItems() because due to the nature of it, it will take doSomeOtherStuff() out of scope.
Hope this makes sense, I've tried to simplify as much as possible.
RobertScheitlin__GISP
Nart,
  This is where a Deferred comes into play.
dojo/Deferred — The Dojo Toolkit - Reference Guide
NartTamash
Right...so what I needed was a chained promise. Sort of tried that before but didn't work cause I didn't know what I was doing
Always on the watch, Robert! Appreciate it!
