PopupTemplate from Client Side Graphics Not Working
10995
14
01-12-2017 09:05 AM
chuckfrank
Hi All,
I'm attempting to create a FeatureLayer from an array of graphics and have been able to get features to display on a map, but I'm not able to click on them to use the PopupTemplate.  In earlier version of the js api 3.x I was able to get this to work, but I haven't had any success with version 4.2.  I've attached all of my code and kept it as simple as possible.  Does anybody know why the PopupTemplate isn't displaying?
Code Follows:
<!DOCTYPE html>
<html lang="en" xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="X-UA-Compatible" content="IE=edge" />
<meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
<meta name="date" content="January 12, 2017" />
<title>Station Location Map</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.2/esri/css/main.css" />
<style>
html, body {
height: 100%;
#viewDiv {
padding: 0%;
margin: 0%;
height: 100%;
width: 100%;
</style>
<script src="https://js.arcgis.com/4.2/"></script>
<script src="http://code.jquery.com/jquery-3.1.1.min.js" integrity="sha256-hVVnYaiADRTO2PzUGmuLJr8BLUSjGIZsDYGmIJLv2b8=" crossorigin="anonymous"></script>
<script>
function station(name, location, latitude, longitude, url) {
   this.name = name;
   this.location = location;
   this.latitude = latitude;
   this.longitude = longitude;
   this.url = url
var stations = [];
stations.push(new station("Station 1", "Canisteo River", 42.1, -77.2, "http://www.google.com"));
stations.push(new station("Station 2", "Juniata River", 40.5, -78.0, "http://www.google.com"));
stations.push(new station("Station 3", "Chiques Creek", 40.2, -76.3, "http://www.google.com"));
console.log('Array is populated...')
require([
"esri/Basemap",
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"esri/layers/MapImageLayer",
"esri/geometry/Point",
"esri/Graphic",
"esri/PopupTemplate",
"esri/renderers/SimpleRenderer",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/widgets/BasemapToggle",
"esri/widgets/Home",
"dojo/domReady!"],
function (
Basemap,
Map,
MapView,
FeatureLayer,
MapImageLayer,
Point,
Graphic,
PopupTemplate,
SimpleRenderer,
SimpleMarkerSymbol,
SimpleLineSymbol,
SimpleFillSymbol,
BasemapToggle,
Home
var stationFeatureLayer;
var fields = [
alias: "ObjectID",
type: "oid"
alias: "name",
type: "string"
alias: "location",
type: "string"
alias: "url",
type: "string"
var popupTemplate = new PopupTemplate({
title: "{name}",
content: [{
type: "fields",
fieldInfos: [{
fieldName: "location",
label: "Location",
visible: true
fieldName: "url",
label: "More info",
visible: true
var map = new Map({
   basemap: "satellite"
var view = new MapView({
   container: "viewDiv",
   map: map,
   zoom: 7,
   center: [-77, 41.25]
// symbolization //
var simpleLineSymbol = new SimpleLineSymbol({
   color: "black",
   width: "1px",
   style: "solid"
// Circle Marker (DEFAULT)
var simpleMarkerSymbolDefault = new SimpleMarkerSymbol({
   style: "circle",
   color: "red",
   outline: simpleLineSymbol
var stationsRenderer = new SimpleRenderer({
symbol: simpleMarkerSymbolDefault,
label: "Monitoring Site"
var basemapToggle = new BasemapToggle({
   view: view,
   nextBasemap: "streets"
basemapToggle.startup();
view.ui.add(basemapToggle, "top-right");
var home = new Home({
   view: view
view.ui.add(home, "top-left");
var graphics = [];
view.then(function () {
   console.log("view.then");
   var i = 0;
   for (s in stations) {
      console.log(stations.latitude);
      var pt = new Point(stations.longitude, stations.latitude);
      var attr = { "ObjectID": i, "name": stations.name, "location": stations.location, "url": stations.url }
      console.log(attr);
      var graphic = new Graphic({
         attributes: attr,
         geometry: pt,
         popupTemplate: popupTemplate
   graphics.push(graphic);
   i = i + 1;
featureLayer = new FeatureLayer({
   source: graphics,
   fields: fields,
   objectIdField: "ObjectID",
   renderer: stationsRenderer,
   geometryType: "point", // Must be set when creating a layer from Graphics
console.log(featureLayer);
map.add(featureLayer);
</script>
</head>
<body>
<div id="viewDiv">
</div>
</body>
</html>
chuckfrank
Hi David,
Using the graphics sample you supplied, I was able to get Popup Templates to work with an array of graphics.  I'm not really sure what was causing the original problem with going the Feature Layer route, but I may revisit that another time.  Originally, I was trying to manually create a Feature Layer because I thought it would give me better capabilities with selections and rendering.  In some troubleshooting while I was coding I noticed that I needed to click at a very precise location in order to to trigger the popup, but I wasn't able to determine the cause, so I just did a complete re-write and the working code is below.  My leading thoughts on what was going wrong with my original attempt would be the way I was populating the source with a function; creating a feature layer in the "view.then"; or possibly the way I was constructing my Popup Template.  Thanks again for your help!
Final Solution - Different Approach that Uses Graphics Instead of Feature Layer Follows:
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8">
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
    <title>Test Map 4.2</title>
    <!--ESRI JavaScript API-->
    <link rel="stylesheet" href="https://js.arcgis.com/4.2/esri/css/main.css">
    <style>
        html,
        body,
        #viewDiv {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
    </style>
    <script>
        require([
          "esri/Map",
          "esri/Graphic",
          "esri/geometry/Polyline",
          "esri/geometry/Polygon",
          "esri/symbols/PictureMarkerSymbol",
          "dojo/domReady!"
        ], function (
          Map,
          MapView,
          Graphic,
          Point,
          Polyline,
          Polygon,
          PopupTemplate,
          PictureMarkerSymbol,
          SimpleMarkerSymbol,
          SimpleLineSymbol,
          SimpleFillSymbol,
          BasemapToggle,
          Home
            // populate the array
                this.name = name;
                this.url = url
            var stations = [];
            stations.push(new station("station 1", "Canisteo River", 42.1, -77.2, "http://www.esri.com/"));
            stations.push(new station("station 2", "Frankstown Branch Juniata River", 40.5, -78.0, "http://www.esri.com/"));
            stations.push(new station("station 3", "Chiques Creek", 40.2, -76.3, "http://www.esri.com/"));
            var map = new Map({
                basemap: "hybrid"
                center: [-77, 41.25],
                map: map,
                zoom: 8
                view: view,  // The view that provides access to the map's "streets" basemap
                nextBasemap: "streets"  // Allows for toggling to the "hybrid" basemap
            // start the basemap toggle widget and add it to the view
                view: view
            // symbolization //
                color: "black",
                width: "1px",
                style: "solid"
            var simpleMarkerSymbol = new SimpleMarkerSymbol({
                style: "circle",
                color: "red",
            var pt = new PopupTemplate({ // autocasts as new PopupTemplate()
                title: "Station: {Station}",
                content: [{
                    type: "fields",
                    fieldInfos: [{
                        fieldName: "Location"
                        fieldName: "Url"
            // loop
                // First create a point geometry (this is the location of the Titanic)
                var point = new Point({
                    longitude: stations[s].longitude,
                    latitude: stations[s].latitude
                // Create an object for storing attributes related to the line
                var pointAtt = {
                    Station: stations[s].name,
                    Url: stations[s].url
                // Create a graphic and add the geometry and symbol to it
                var pointGraphic = new Graphic({
                    geometry: point,
                    symbol: simpleMarkerSymbol,
                    attributes: pointAtt,
                    popupTemplate: pt
                // Add the graphics to the view's graphics layer
                view.graphics.add(pointGraphic);
    </script>
</head>
<body>
    <div id="viewDiv">
    </div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DavidColey
MVP Frequent Contributor
Yeah there you go. Much cleaner.  This will help others too for sure
KevinCheriyan
Looks like this is still an issue with ArcGIS API for JavaScript 4.x. Feature Layer with a source of client side graphics cannot be interacted with on the webmap. PopupTemplate doesn't work in that you can't get a popup to appear. And also, hitTest() doesn't work, since the mapPoint doesn't recognize the features that are clicked on. See other post here from someone else a while back:
https://community.esri.com/thread/189210-viewhittest-returning-0-results
Application Developer, GeoMarvel
VincentJones
I managed to get this working (PopupTemplate on a feature layer with client side graphics) using version 4.11 and 4.12 of the API but it appears not to work again in any version since.
VincentJones
I finally tracked down what the issue was here. In my case I was reading the objectId from a data attribute and although a numeric value, it's type must have been considered string by the API; parsing as integer fixed the issue.
