PopupTemplate Content strips HTML Data-* Attributes in 4.16
3037
07-25-2020 05:41 PM
BernardConrad
Working with the ArcGIS JavaScript API version 4.13 and was able to build popup templates that included data attributes to work with the Semantic UI library for their Tab module (https://semantic-ui.com/modules/tab.html). I recently upgraded to version 4.16 and now the template is broken. Upon examining the html when rendered it strips key data-attributes for tabs (data-tab) prevent it from working. Is there a way to force explicit content and prevent the template from being modified in version 4.16 or if this expected going forward? Thanks.
Example (Click on the map to launch the popup)
Version 4.13 Working: https://codepen.io/booshwa/pen/ExPJgRz
Version 4.16 Broken: https://codepen.io/booshwa/pen/qBbwaJB
KenBuja
MVP Esteemed Contributor
There was a breaking change in 4.14 where HTML code will be sanitized
The HTML sanitizer was added to all widgets to sanitize and escape strings according to the ArcGIS Online supported HTML specification. This can cause HTML set in PopupTemplate.content or in other widgets to be removed.
Take a look at this blog that shows how to modify the popup's DOM directly
Using HTML with Popups in the ArcGIS API for JavaScript
KenBuja
BjornSvensson
Esri Alum
FYI - I answered the exact same question at
 https://gis.stackexchange.com/questions/368729/popuptemplate-content-strips-html-data-attributes-in-...
Pretty much the same answer, but a few hours later...
