Popup window doesn't work
2749
10-30-2014 01:19 PM
ShruthiR
I tried creating a popup window in map. When I run my program , it gets the basemap and the icons on the map , but not the popup window. Firebug throws this error
Error: Unable to draw graphic (null): Unable to complete operation.
...usePost,v=h.crossOrigin):A=!!h);g=e.mixin({},g);g._ssl&&(g.url=g.url.replace(/^h...
/3.11/ (line 871)
To solve this, I tried adding time between the layers, It didn't solve the problem. Below is my code. Please let me know, if I am making any mistake. Thanks!
<!DOCTYPE html>
<html>
  <head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
  on iOS devices-->
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <title> Trees Location</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.11/"></script>
  <script>
  var map;
  require(["esri/config", "esri/map","esri/dijit/Popup",
  "dojo/dom-construct",
  "esri/dijit/PopupTemplate",
  "esri/layers/FeatureLayer",
  "esri/symbols/SimpleMarkerSymbol",
  "esri/tasks/GeometryService",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/layers/ArcGISTiledMapServiceLayer",
  "esri/Color",
  "dojo/domReady!"],
  function (esriConfig, Map,Popup,domConstruct, PopupTemplate, FeatureLayer,SimpleMarkerSymbol, GeometryService, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, Color ) {
esriConfig.defaults.geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
  var popupOptions = {
  markerSymbol: new SimpleMarkerSymbol("circle", 32, null,
  new Color([0, 0, 0, 0.25])),
  marginLeft: "20",
  marginTop: "20"
  var popup = new Popup(popupOptions, domConstruct.create("div"));
  map = new Map("map", {
  center: [-76.756, 40.241],
  zoom: 8,
  infoWindow: popup
  var popupTemplate = new PopupTemplate({
  title: "{address}",
  fieldInfos: [
  fieldName: "Tredonor",
  visible: true,
  label: "Type"
  fieldName: "Trespecies",
  visible: true,
  label: "Type"
  fieldName: "Trevariety",
  visible: true,
  label: "Type"
  var customBasemap = new ArcGISTiledMapServiceLayer(
  map.addLayer(customBasemap);
  /* setTimeout(function(){
  console.log("pausing a few seconds");
},1000); */
  var treeLayer = new ArcGISDynamicMapServiceLayer(
  // map.addLayer(treeLayer);
},1000);
var featureLayer = new FeatureLayer("",
  infoTemplate: popupTemplate,
  outFields: ["Tredonor","Trespecies","Trevariety", "address"]
  featureLayer.setDefinitionExpression("MEMORIAL != ''");
  map.addLayer(featureLayer);
</script>
</head>
<body class="claro">
<div align="center"><strong> Trees Listing   </strong><hr>
<i><a target="_self" href="listingtrees.html">Listing</a> | <a target="_self" href="locationtrees.html">Locations </a></i>
</div>
<br>
<div id="map" >
</div>
</body>
</html>
JanJeske
Hey I modifed the Popup examle code for your Problem i hope it helps u a bit.
https://developers.arcgis.com/javascript/jssamples/popup_chart.html
BTW: the <hr> Element is depreached also the attribut align. You should use CSS for that.
var map;
      require([
        "esri/map",
        "esri/dijit/Popup", "esri/dijit/PopupTemplate",
        "esri/symbols/SimpleFillSymbol", "esri/Color",
        "dojo/dom-class", "dojo/dom-construct", "dojo/on","esri/layers/ArcGISDynamicMapServiceLayer",
        "dojox/charting/Chart", "dojox/charting/themes/Dollar",
        "dojo/domReady!"
      ], function(
        Map,
        Popup, PopupTemplate,
        FeatureLayer,
        SimpleFillSymbol, Color,
        domClass, domConstruct, on,ArcGISDynamicMapServiceLayer,ArcGISTiledMapServiceLayer,
        Chart, theme
        //The popup is the default info window so you only need to create the popup and
        //assign it to the map if you want to change default properties. Here we are
        //noting that the specified title content should display in the header bar
        //and providing our own selection symbol for polygons.
        var fill = new SimpleFillSymbol("solid", null, new Color("#A4CE67"));
        var popup = new Popup({
            fillSymbol: fill,
            titleInBody: false
        }, domConstruct.create("div"));
        //Add the dark theme which is customized further in the <style> tag at the top of this page
        domClass.add(popup.domNode, "dark");
          center: [-98.57, 39.82],
          zoom: 4,
          infoWindow: popup
        var template = new PopupTemplate({
          title: "Boston Marathon 2013",
          description: "{STATE_NAME}:  {Percent_Fi} of starters finished",
          fieldInfos: [{ //define field infos so we can specify an alias
            fieldName: "Number_Ent",
            label: "Entrants"
            fieldName: "Number_Sta",
            label: "Starters"
            fieldName: "Number_Fin",
            label: "Finishers"
          mediaInfos:[{ //define the bar chart
            caption: "",
            type:"barchart",
            value:{
              theme: "Dollar",
              fields:["Number_Ent","Number_Sta","Number_Fin"]
        var basemap = new ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer");
        map.addLayer(basemap);
        var usaLayer = new ArcGISDynamicMapServiceLayer("http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer", {
          opacity: 0.7,
          visible: false
        usaLayer.setVisibleLayers([2]);
        map.addLayer(usaLayer);
        var featureLayer = new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Boston_Marathon/FeatureServer/0",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"],
          infoTemplate: template
JanJeske
var map;
      require([
        "esri/map",
        "dojo/domReady!"
      ], function(
        Map,
        FeatureLayer,
        Chart, theme
            fillSymbol: fill,
            titleInBody: false
          zoom: 4,
          infoWindow: popup
            label: "Entrants"
            label: "Starters"
            label: "Finishers"
            caption: "",
            type:"barchart",
            value:{
              theme: "Dollar",
          opacity: 0.7,
          visible: false
          outFields: ["*"],
ShruthiR
I have tried modifying my code as yours, it doesn't create popup window. I get the map and the icons but does not create the window. Below is the modified code, can you please see it, let me know if I'm missing something or I'm making some mistake.
<!DOCTYPE html>
<html>
    <head>
        <title>BGSU Memorial Trees Location</title>
        </script>
        <script>
            var map;
            require(["esri/map", "esri/dijit/Popup", "esri/dijit/PopupTemplate",
          "esri/layers/FeatureLayer", "esri/symbols/SimpleMarkerSymbol", "esri/Color", "dojo/dom-class",
  "dojo/dom-construct", "dojo/on", "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/layers/ArcGISTiledMapServiceLayer", "dojo/domReady!"],
  function(Map, Popup, PopupTemplate, FeatureLayer, SimpleMarkerSymbol,
           Color, domClass, domConstruct, on, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer){
                var popupOptions = new SimpleMarkerSymbol("solid", 32, null, new Color("#A4CE67"));
  //create popup window
                var popup = new Popup(popupOptions, domConstruct.create("map"));
                    zoom: 8,
                    infoWindow: popup // assign popup to the map
                    title: "{MEMORIAL TREE}",
                    fieldInfos: [{                          //defining field infos
                        fieldName: "MEMORIAL_TREE_DONOR",
                        label: "Type"
                        fieldName: "TREE_SPECIES",
                        label: "Type"
                        fieldName: "TREE_VARIETY",
                        label: "Type"
                // map layer
                var basemap = new ArcGISTiledMapServiceLayer("https://gistest2.bgsu.edu/arcgis/rest/services/Basemap/gisbasemap/MapServer");
                // tree icon layer
                var treeLayer = new ArcGISDynamicMapServiceLayer("https://gistest2.bgsu.edu/arcgis/rest/services/MemorialTrees/MemorialTEST/MapServer");
                // info
                var featureLayer = new FeatureLayer("https://gistest2.bgsu.edu/arcgis/rest/services/MemorialTrees/MemorialTEST/MapServer/0", {
                infoTemplate: template,
                outFields: ["MEMORIAL_TREE_DONOR", "TREE_SPECIES", "TREE_VARIETY", "MEMORIAL"]
        </script>
    </head>
    <body>
        <div id="map">
        </div>
    </body>
</html>
Thank you very much for seeing this!
