Popup window does not show close symbol
4132
07-19-2012 06:36 AM
BillShockley
Hello, hopefully this is a simple problem.  I am working with this sample:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples_start.htm#jssamples/fl_popup.html
I got my info to work with it, but my popup window is missing the symbol to close or scroll through the infomation:
ESRI version:
[ATTACH=CONFIG]16249[/ATTACH]
my verison:
[ATTACH=CONFIG]16250[/ATTACH]
sometimes the callout arrow does not even appear.  What is causing this?
Thanks in advance.
SiqiLi
by Esri Contributor
Hi Bill,
Thank you for pointing this out. Just a quick tip I want to share with you, if you haven't used it. To find out the correct path, an easy way is to use a web development tool (e.g. Firebug, Fiddler, and etc.) to track the requests. I used firebug for this case, and firebug shows which path it looks into for the image. That is how I found out the popup.png needs to be put in the wwwroot/images folder. Hope this tip is helpful. Thanks.
[ATTACH=CONFIG]16287[/ATTACH]
StephenLead
Honored Contributor
Hi Bill,
Note the line at the top of the HTML page for that sample, which includes some specific CSS for the popup. Have you definitely included that in your code:
 <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/esri/dijit/css/Popup.css">
Steve
by Anonymous User
Not applicable
Original User: bmwgsbill
Hi Bill,
Steve
Yes I have that in my code.  Any other suggestions?
SiqiLi
by Esri Contributor
The online sample gets a "popup.png" from http://help.arcgis.com/en/webapi/javascript/arcgis/demos/images/popup.png. The "popup.png" contains the close, minimize, next arrow, and etc icons.
When you put the sample onto your IIS, it tries to get the "popup.png" from http://<your server name>/images/popup.png. But because the image doesn't exist on your IIS, it returns NetworkError: 403 Not Found error.
So, please go ahead to download the "popup.png" and put it into your wwwroot/images folder. It shall fix the issue.
by Anonymous User
Not applicable
the image was there.....I just had the path incorrect.  Thanks.  I really wish ESRI would had comments into the sample section as to where a new user like myself needs to make changes.  This one was simple...but it can drive a person crazy trying to figure it all out.
SiqiLi
by Esri Contributor
Hi Bill,
