Popup to DIV
7447
18
07-24-2018 09:56 AM
jaykapalczynski
Honored Contributor
I have the below code that is returning a popup window via a map click.  The data I have is getting to large for a popup and want to move this to an HTML DIV in a side window.
Anyone have any examples of how to push this to an html div tag instead of a popup?
var infoTemplateHazmat = new InfoTemplate();
infoTemplateHazmat.setTitle("Hazmat Incidents");
infoTemplateHazmat.setContent("<table>" +
     "<tr><td>Status</td><td>${status}</td></tr>" +
     "<tr><td>Datetime</td><td><i>${UTC_DATETIME}</i></td></tr>" +
     "</table><hr>");
var hazmat = new FeatureLayer("https://arcgis.vdem.virginia.gov/ArcGIS/rest/services/Traffic/VATraffic_IncidentPoints/MapServer/4", {
    mode: FeatureLayer.MODE_ONDEMAND,
    visible: false,
    outFields:["*"],
    infoTemplate: infoTemplateHazmat
legendLayers.push({ layer: hazmat, title: 'Hazmat Incidents' });‍‍‍‍‍‍‍‍‍‍‍‍‍
KenBuja
MVP Esteemed Contributor
I'm sorry, I gave you an incorrect answer. You only want to fire off the initializeSidebar function when the map loads. You should use the setInfoWindowOnClick method on the map instead
map.on('load', initializeSidebar());
on(dom.byId("PauseButton"), "click", TestingPause);
on(dom.byId("ResumeButton"), "click", TestingResume);
function TestingPause() {
  map.setInfoWindowOnClick(false);
function TestingResume() {
  map.setInfoWindowOnClick(true);
jaykapalczynski
Honored Contributor
I am pretty confused.  If I modify the code to eliminate the ClickEvent variable and add the Map.on load to call the function my app freezes with no apparent error in the console
     map = new Map("map", {
      basemap: "gray",
      center: [-79.665, 37.629],
      zoom: 8,
       logo: false,
       showLabels : true
   //resize the info window
    map.infoWindow.resize(350, 400);
   // Disable popup window from appearing in the map
    map.infoWindow.set("popupWindow", false);
    //setup event handlers for the next/previous buttons
    on(dom.byId("previous"), "click", selectPrevious);
    on(dom.byId("next"), "click", selectNext);
     //var clickEvent = on.pausable(dom.byId("ClickButton"), "click", initializeSidebar);
     on(dom.byId("ResumeButton"), "click", initializeSidebarResume);
     on(dom.byId("PauseButton"), "click", initializeSidebarPause);
          function initializeSidebarPause() {
            //clickEvent.pause();
          function initializeSidebarResume() {
            //clickEvent.resume();
          function initializeSidebar() {
          var popup = map.infoWindow;
             // SNIP
          function displayPopupContent(feature) {
            if (feature) {
              var content = feature.getContent();
              registry.byId("leftPaneInfo").set("content", content);
          function selectPrevious() {
            map.infoWindow.selectPrevious();
          function selectNext() {
            map.infoWindow.selectNext();
jaykapalczynski
Honored Contributor
Even if I do this the application freezes.  Something is not letting me to the map.on
I get the alert but then the app freezes.
map.on('load', Test());
function Test() {
      alert("test");
I have a ton of requires as the app is rather large at this point...maybe the error is there?
 require([
"esri/map", "esri/geometry/webMercatorUtils", "dojo/dom", "esri/layers/FeatureLayer", "esri/dijit/Legend","esri/symbols/SimpleFillSymbol",
"esri/layers/ArcGISImageServiceLayer", "esri/layers/ImageServiceParameters",
"esri/geometry/Extent", "esri/layers/ArcGISDynamicMapServiceLayer", 'esri/layers/WMSLayer', 'esri/layers/WMSLayerInfo', "esri/layers/ImageParameters",
"dojo/_base/array", "dojo/on", "esri/graphic","esri/graphicsUtils","esri/tasks/Geoprocessor","esri/tasks/FeatureSet","esri/tasks/LinearUnit","esri/symbols/SimpleLineSymbol",
"esri/renderers/SimpleRenderer", "esri/symbols/SimpleMarkerSymbol","esri/layers/LabelClass", "esri/dijit/BasemapToggle","esri/dijit/HomeButton", "esri/dijit/Search", "esri/dijit/LocateButton",
"esri/urlUtils", "esri/dijit/Directions",
"esri/toolbars/draw","esri/symbols/CartographicLineSymbol",
"dijit/registry", "esri/arcgis/utils", "esri/domUtils", "esri/dijit/Popup", "dojo/_base/connect",
"esri/Color", "dojo/_base/array", "dojo/parser", "esri/InfoTemplate", "esri/renderers/ClassBreaksRenderer","dijit/form/CheckBox", "dojo/dom-construct",
"dojo/keys","esri/SnappingManager","esri/dijit/Measurement","esri/tasks/GeometryService","esri/config",     "esri/sniff","esri/dijit/BasemapGallery",
"esri/layers/LabelLayer", "esri/symbols/TextSymbol", "esri/symbols/Font", "esri/symbols/SimpleLineSymbol",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dijit/layout/AccordionContainer","esri/dijit/Scalebar","dijit/TitlePane", "dojo/domReady!"
      ], function(
        Map, webMercatorUtils, dom, FeatureLayer, Legend,
     SimpleFillSymbol,
     ArcGISImageServiceLayer, ImageServiceParameters,
     Extent, ArcGISDynamicMapServiceLayer, WMSLayer, WMSLayerInfo,
     ImageParameters,
     array, on, Graphic, graphicsUtils, Geoprocessor, FeatureSet,
     LinearUnit, SimpleLineSymbol,
     SimpleRenderer, SimpleMarkerSymbol, LabelClass, BasemapToggle,
     HomeButton, Search, LocateButton,
        urlUtils, Directions,
     Draw, CartographicLineSymbol,
     registry, arcgisUtils, domUtils, Popup, connect,
     Color, arrayUtils, parser, InfoTemplate, ClassBreaksRenderer,
     CheckBox, domConstruct,
     keys,SnappingManager, Measurement, GeometryService,esriConfig, has,
     BasemapGallery,
     LabelLayer, TextSymbol, Font, SimpleLineSymbol
KenBuja
Are there any messages in the console?
jaykapalczynski
Honored Contributor
I don get anything in the console when I comment it out or uncomment it...
Right now I commented all the code we have been working on and simply trying to do the below.  I get the Alert to show up but the app freezes and I don get anything in the console...
function Test() {
      alert("test");
jaykapalczynski
Honored Contributor
Think I got it...I changed the Map.onload from this to this...still testing...Dont know why this would matter but it seems like it is working.
FROM THIS:
function Test() {
    alert("test");
TO THIS:
map.on('load', function () {
    // SNIP
jaykapalczynski
Honored Contributor
That seems to have done the trick....combining the on.load and function....although I dont understand why????
Thoughts?  Thank you for your help....very much appreciated.
KenBuja
There must have been some other syntax problem in your code. The load function works as expected using the basic Create a Map sample, although you should probably use
map.on('load', Test);
jaykapalczynski
Honored Contributor
OK I see two locations
I will look at the other locations that you mentioned in you last post....I was somewhat close hahaha
THANKS
This:
 map.on(initializeSidebar(window.map));
        function initializeSidebar(map) {
Changed to this:
