Popup Style Issues
4443
11-16-2016 01:58 PM
TylerWaring
Greetings, I'm working with popups in an ESRI Javascript API 3.18 bootstrapmap.js map and my popups are not styling correctly. It appears to me like I am missing both the minimize and maximize buttons and the popup pointers appear to not be drawing correctly. See below:
Missing minimize and maximize buttons and popup pointer stacking.
Initially the popup titlePane was white and the close button was invisible. I followed the directions at Making Your Pop-up Pop! | ArcGIS Blog and copied the css from http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/esri/dijit/css/Popup.css  and that got me this far.  How do I take this the rest of the way?
Thanks, Tyler
Tags (1)
RobertScheitlin__GISP
Tyler,
  Here is what I have working:
<!DOCTYPE html>
<html>
  <head>
    <title>Bootstrap 101 Template</title>
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no">
    <!-- Bootstrap -->
    <link href="http://maxcdn.bootstrapcdn.com/bootstrap/3.3.2/css/bootstrap.min.css" rel="stylesheet" media="screen">
    <!-- Step 1. Add CSS for the mapping components -->
    <link rel="stylesheet" type="text/css" href="http://js.arcgis.com/3.18/esri/css/esri.css">
    <link rel="stylesheet" type="text/css" href="http://esri.github.io/bootstrap-map-js/src/css/bootstrapmap.css">
    <style>
      #mapDiv {
        min-height: 100px;
        max-height: 1000px;
      .esriPopup .titlePane, .esriPopup.light .titlePane, .esriPopup.dark .titlePane {
        background-color: rgb(112,112,112);
      /* Change color of icons to match bar chart and selection symbol */
      .esriPopup.dark div.titleButton,
      .esriPopup.dark div.titlePane .title,
      .esriPopup.dark div.actionsPane .action {
        color: #A4CE67;
      /* Additional customizations */
      .esriPopup.dark .esriPopupWrapper {
        border: none;
      .esriViewPopup .gallery {
        margin: 0 auto;
    </style>
    <!-- HTML5 IE8 support of HTML5 elements and media queries -->
    <!--[if lt IE 9]>
      <script src="../assets/js/html5shiv.js"></script>
      <script src="../assets/js/respond.min.js"></script>
    <![endif]-->
  </head>
  <body>
    <!-- Step 2. Add HTML to define the layout of the page and the map -->
    <div class="container">
      <div id="mapDiv"></div>
    </div>
    <!-- Step 3. Add JS to load the responsive map -->
    <script>
        var package_path = window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/'));
        var dojoConfig = {
            packages: [{
                location: "http://rawgit.com/xsokev/Dojo-Bootstrap/master"
    </script>
    <script src="http://js.arcgis.com/3.18/"></script>
    <script>
        require(["esri/map", "esri/layers/FeatureLayer", "application/bootstrapmap", "esri/dijit/PopupTemplate", "esri/dijit/Popup", "dojo/dom-construct", "dojo/dom-class","dojo/domReady!"],
          function(Map, FeatureLayer, BootstrapMap, PopupTemplate, Popup, domConstruct, domClass) {
            var popup = new Popup({
                titleInBody: true
            }, domConstruct.create("div"));
            //Add the dark theme which is customized further in the <style> tag at the top of this page
            domClass.add(popup.domNode, "dark");
            // Get a reference to the ArcGIS Map class
            var map = BootstrapMap.create("mapDiv",{
              basemap:"national-geographic",
              center:[-122.45,37.77],
              zoom:12,
              infoWindow: popup
            var popupTemplate = new PopupTemplate({
                "title": "Location",
                "description": "<b>Crime Desc: </b> {Desc_} </br><br/> <b>Case #: </b> {Case_Num}"
            var featureLayer = new FeatureLayer("my url/0", {
                mode: FeatureLayer.MODE_SNAPSHOT,
                infoTemplate: popupTemplate,
                opacity:1,
                outFields: ["*"]
            map.addLayers([featureLayer]);
    </script>
  </body>
</html>
Tyler,
<!DOCTYPE html>
<html>
  <head>
    <!-- Bootstrap -->
    <style>
      #mapDiv {
        min-height: 100px;
        max-height: 1000px;
        color: #A4CE67;
        border: none;
        margin: 0 auto;
    </style>
    <!--[if lt IE 9]>
    <![endif]-->
  </head>
  <body>
    </div>
    <script>
        var dojoConfig = {
            packages: [{
    </script>
    <script>
                titleInBody: true
              zoom:12,
              infoWindow: popup
                opacity:1,
                outFields: ["*"]
    </script>
  </body>
</html>
TylerWaring
Hi Robert, Thanks for providing me this template. The css that you provided fixed my issue. However, in my original application I am not referencing bootstrapmap.js only bootstrapmap.css. Is that an issue? Should I be using bootstrapmap.js as you are?  If so, I'm getting a 404 on bootstrapmap.js in this template. I dug a little deeper and found the 404 at:
I downloaded bootstrap map locally and changed the dojoConfig to:
        var dojoConfig = {
            packages: [{
However, I'm getting a BootstrapMap is not a constructor when i create my map.
Any idea how I should proceed?
Thanks, Tyler
Tyler,
   I followed the instructions found here and the code I provided worked fine:
Bootstrap Map JS - Get Started
TylerWaring
Thanks Robert, I'll continue to play around with it. I'm sure I must have made a mistake somewhere. It's probably a good time for me to walk away and come back. My popups look awesome, now. And that is what I needed. Thanks for your help!
Tyler
