Popup in 4.2 with coordinates and address work in 3D SceneView?
2502
01-24-2017 05:25 AM
DavidChrest
Does the sample here Get started with popups | ArcGIS API for JavaScript 4.2  work in SceneView? Can I capture coordinates in a SceneView? Can they be captured with mouse-move or mouse-drag events?
RobertScheitlin__GISP
David,
   It seems that there is a timing issue when using this sample with a SceneView. Adding a timeout to 50 milliseconds works fine:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Get started with popups - 4.2</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #instruction {
      z-index: 99;
      position: absolute;
      top: 15px;
      left: 50%;
      padding: 5px;
      margin-left: -175px;
      height: 20px;
      width: 350px;
      background: rgba(25, 25, 25, 0.8);
      color: white;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.2/esri/css/main.css">
  <script src="https://js.arcgis.com/4.2/"></script>
  <script>
    require([
      "esri/tasks/Locator",
      "esri/Map",
      "esri/views/MapView",
      "esri/views/SceneView",
      "dojo/domReady!"
    ], function(
      Locator,
      Map,
      MapView,
      SceneView
      // Set up a locator task using the world geocoding service
      var locatorTask = new Locator({
        url: "https://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer"
      var map = new Map({
        basemap: "streets-navigation-vector",
        ground: "world-elevation"
      var view = new SceneView({
        container: "viewDiv",
        map: map,
        zoom: 12,
        center: [-116.3031, 43.6088]
       * This click event sets generic content on the popup not tied to
       * a layer, graphic, or popupTemplate. The location of the point is
       * used as input to a reverse geocode method and the resulting
       * address is printed to the popup content.
      view.on("click", function(event) {
        // Get the coordinates of the click on the view
        var lat = Math.round(event.mapPoint.latitude * 1000) / 1000;
        var lon = Math.round(event.mapPoint.longitude * 1000) / 1000;
        setTimeout(function(){
          view.popup.open({
            // Set the popup's title to the coordinates of the location
            title: "Reverse geocode: [" + lon + ", " + lat + "]",
            location: event.mapPoint // Set the location of the popup to the clicked location
        }, 50);
        // Display the popup
        // Execute a reverse geocode using the clicked location
        locatorTask.locationToAddress(event.mapPoint).then(function(
          response) {
          // If an address is successfully found, print it to the popup's content
          var address = response.address.Match_addr;
          view.popup.content = address;
        }).otherwise(function(err) {
          // If the promise fails and no result is found, print a generic message
          // to the popup's content
            "No address was found for this location";
  </script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="instruction">Click any location on the map to see its street address</div>
</body>
</html>
David,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #instruction {
      z-index: 99;
      position: absolute;
      top: 15px;
      left: 50%;
      padding: 5px;
      height: 20px;
      width: 350px;
      color: white;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/domReady!"
    ], function(
      Locator,
      Map,
      MapView,
      SceneView
      var map = new Map({
        map: map,
        zoom: 12,
          view.popup.open({
        }, 50);
          response) {
  </script>
</head>
<body>
</body>
</html>
DavidChrest
Robert, yep, that did it. Thanks so much! I did also see your setTimeout solution for another post in using view.goTo. Looks like a common theme here in use of the 3D SceneView.
