Popup does not render Graphic PopupTemplate content in 4.5
3589
7
10-18-2017 11:09 AM
BradleyChappell
I built a web application using the JS 4.4 API and have recently upgraded the JS source to 4.5. When I changed the script and style sources to 4.5, my Popup quit rendering the content.
Here is the content of the Graphic's popup template (which is logged during runtime to the console):
<div class='popupEntry'>Network: {Network}</div><div class='popupEntry'>County: {County}</div><div class='popupEntry'>Residential Buildings: {Residential_Bldgs}</div>
Here is the popup rendered in 4.4:
Popup 4.4
Here is the  popup rendered in 4.5:
Popup 4.5
Also, my custom action is present in each, but only works in 4.4.
In 4.5 it throws an error "a is null" in MapView.js 1771:486
Browser: Firefox
ToddAtkins
I stumbled across this in the API documentation the other day. I wonder if that has some relation to your issue?
As of version 4.5, if the popupTemplate is not defined on the Graphic, it will use the graphic layer popupTemplate.
BradleyChappell
Thanks for the response.  I am defining the popupTemplate for each Graphic though, so it should use that as opposed to the graphic layer. Actually, I'm not even creating a graphic layer.  Instead, I am just setting my Graphics[] to the View.Popup.Features property.
RobertScheitlin__GISP
You should try adding them to a Graphics Layer than and define the PopupTemplate for the GL and not the graphic as the docs now state for 4.5.
BradleyChappell
I will try a graphics layer, but the keyword in the documentation is "if":
I don't see anything that states the popupTemplate MUST be defined in the graphic layer.
Ok I totally missed the “if”.
YueZhou1
I used to set popupTemplate for each graphic (view.popupTemplate does not work) in version 4.4. Now it's broken in 4.5 and I don't know how to fix it.
view.on("click", function (event) {
   event.stopPropagation();
   var ext = pointToExtent(view, event.mapPoint, 10);
   view.popup.features = findPointsInExtent(ext);
   if (view.popup.features.length > 0)
      { view.popup.open({location: event.mapPoint}); }
BradleyChappell
I just came back to this problem after a few weeks of doing other things.  Now, the popup renders the graphic template without any changes to my code.
ESRI must have made some update to their API.
Can someone from ESRI confirm any update to the 4.5 API?
