Popup contents
1300
01-30-2014 05:49 AM
Dianede_lanfranchi
I'm trying to get the ID of a point using this sample
the intersting part of the code is here
connect.connect(popup, "onSelectionChange", function(){                 displayPopupContent(popup.getSelectedFeature());                     });
which call
            function displayPopupContent(feature){                 if(feature){                     var content = feature.getContent();                     registry.byId("leftPane").set("content", content);                   }             }
I'd like to get the value of the "content" variable, I could get it using leftPane but my goal is to get it before it goes to the leftPane. If I alert(content) it simply return a [object htmldivelement]. Btw, the content that appears in the leftPane is just an ID in my case.
JakeSkinner
Esri Esteemed Contributor
Hi Diane,
You can get this by calling the feature variable passed to the 'displayPopupContent' function.  Ex:
function displayPopupContent(feature){                 if(feature){                     console.log(feature.attributes.ID);                 } }
JakeSkinner
Hi Diane,
Dianede_lanfranchi
Hi Jake, that's exactly what I was looking for, thanks alot !
