Popup content
1757
07-29-2013 12:05 AM
Dianede_lanfranchi
Hey,
I was browsing forum & api without any result to my query, I'd like to get the data from my popup in order to re-use it with an AJAX function. cannot find a way to do it.
I'm already moving my popup next to the map so I though it would be easy to get one of the field.
I got this part of code from an arcgis tuto
                    var content =feature.getContent();
                    registry.byId("leftPane").set("content", content);
[HTML]<div id="leftPane" data-dojo-type="dijit/layout/ContentPane"
            data-dojo-props="region:'center'"></div>[/HTML]
The content properly get into the leftPane DIV but whenever I try to use it another way than this one I got a 'object HTMLDivElement' as result.
thanks
JanJeske
Hey if you display the Popup with features try
popup.getSelectedFeature()
. You'll get a feature object back. If you want all features wich are set to the popup look at the dom ;).... in my case
popup.features
(is an array)
if you use a template u can use:
var template = new esri.InfoTemplate("","${Status:compare}");
in this case Status is a returned var and compare is the function.
function compare(value, key, data)
var content = "The Status of XYZ is" + data.Status;
registry.byId("leftPane").set("content", content); //show in left Pane
return content; //show in Popup
btw:
i createt a simple popup with
popup = new esri.dijit.Popup({
   markerSymbol:popupmarker,
   fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25]))
}, dojo.create("div"));
Hope it helps 😉
Dianede_lanfranchi
It helped !
thanks you !
SorinCiolofan
Hi, I have the same problem as described below
Hey,
thanks
feature is obtained popup.getSelectedFeature() - accordingly to the JS ArcGIS API reference https://developers.arcgis.com/en/javascript/jsapi/popup.html it should return a Graphic object.
then when trying to use feature.getContent() on the documentation https://developers.arcgis.com/en/javascript/jsapi/graphic-amd.html says we should get a String but actually seems an Object is returned and not a String.
Seems there is a problem somewhere.
