popup action parse selected attribution as Jsonor Table Div
3220
8
08-13-2017 04:46 PM
Henryobaseki
Hi All
Got the sample code from the link below
https://developers.arcgis.com/javascript/latest/sample-code/popup-custom-action/index.html
I have modified the attribute table to fit to my attribute table.
so from the sample if you click on the bewrey info, instead of linking to a website.
I want to Location attribute to be return as a table or json.
see the code below. I have set var info to get the LOCATION.  How do I parse it so it shows as as a json format or table?
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Custom popup actions per feature attribute - 4.4</title>
  <style>
    body {
      font-family: sans-serif;
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #viewDiv {
      position: absolute;
      right: 0;
      left: 0;
      top: 0;
      bottom: 0;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.4/esri/css/main.css">
  <script src="https://js.arcgis.com/4.4/"></script>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/layers/FeatureLayer",
      "dojo/domReady!"
    ], function(
      Map, MapView, FeatureLayer
      var map = new Map({
        basemap: "streets-navigation-vector"
      var view = new MapView({
        container: "viewDiv",
        map: map,
        center: [0.46564130, 51.736810] ,
        zoom: 17
       * Add feature layer
      // sampling of breweries
      var featureLayer = new FeatureLayer({
        outFields: ["*"],
       // definitionExpression: "country = 'United States'",
        // add a custom action
        popupTemplate: {
          title: "{name}",
          content: [{
            type: "fields",
            fieldInfos: [{
              fieldName: "LOCATION"
              fieldName: "address1",
              label: "address"
              fieldName: "city"
            fieldName: "state"
              fieldName: "phone"
              fieldName: "website"
          actions: [{
            image: "beer.png",
            title: "Brewery Info"
      map.add(featureLayer);
var resultsTable = dom.byId("tbl");
        function showResults(response) {
          var results = response.results;
  // Clear the cells and rows of the table to make room for new results
        resultsTable.innerHTML = "";
        if (results.length === 0) {
          resultsTable.innerHTML = "<i>No results found</i>";
          loadingImg.style.visibility = "hidden";
          return;
      view.then(function() {
        var popup = view.popup;
        popup.viewModel.on("trigger-action", function(event) {
          if (event.action.id === "find-ADDRESS") {
            var attributes = popup.viewModel.selectedFeature.attributes;
            // Get the "website" field attribute
            var info = attributes.LOCATION;
            // Make sure the "website" attribute value is not null
            if (info !== null) {
              // Open up a new browser using the URL value in the 'website' field
              //CELL.open(info.trim());
                showResults();
              // If the "website" value is null, open a new window and Google search the name of the brewery
  </script>
</head>
<body class="light">
  <div id="viewDiv">
  </div>
</body>
</html>
Tags (1)
RobertScheitlin__GISP
Henry,
 You will have to have a table in your layout and then use domConstruct to dynamically add rows to that table. You can't just say return me an html table.
Henry,
  Here is your code returning the location attribute to the console and some comments:
<!DOCTYPE html>
<html>
<head>
  <style>
    body {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
      overflow: hidden;
    #viewDiv {
      position: absolute;
      right: 0;
      left: 0;
      top: 0;
      bottom: 0;
  </style>
  <script>
    require([
      "esri/Map",
      "dojo/dom",
      "dojo/domReady!"
    ], function(
      Map, MapView, FeatureLayer, dom
      var map = new Map({
        map: map,
        center: [0.46564130, 51.736810],
        zoom: 17
       * Add feature layer
        url: "https://services1.arcgis.com/BZNs0xaSHDSi4V6G/arcgis/rest/services/Esri_carparks/FeatureServer/0",
        outFields: ["*"],
        popupTemplate: {
          title: "{name}",
          content: [{
            type: "fields",
            fieldInfos: [{
              fieldName: "LOCATION",
              label: "Location"
              fieldName: "NO_SPACES",
              label: "No Spaces"
              fieldName: "SATURDAY",
              label: "Saturday"
              fieldName: "WHO_OWNS",
              label: "Owner"
              fieldName: "USE_TIME",
              label: "Use Time"
              fieldName: "USE_TYPE",
              label: "Use Type"
          actions: [{
            title: "Parking Info"
//you do not have a html element with id of tbl.
      // var resultsTable = dom.byId("tbl");
        // var results = response.results;
        // resultsTable.innerHTML = "";
        // if (results.length === 0) {
        //   resultsTable.innerHTML = "<i>No results found</i>";
        //   loadingImg.style.visibility = "hidden";
        //   return;
        console.info(response);
              showResults(info.trim());
  </script>
</head>
  <div id="viewDiv">
  </div>
</body>
</html>
Henryobaseki
Thanks Robert Scheitlin. Will the console get the attribution as html table or a text string?
Henry,
   Just a text string.
Henryobaseki
I want to be able to see this text string  in a table next to the mapview, how do I do this. I thought the tablediv will be useful
Henryobaseki
how do will the text string be played as a html or table div
Henry,
Henryobaseki
Alright thank you
Don't forget to mark this question as answered by clicking on the "Correct Answer" link on the reply that answered your question.
