Identify features in popup widget from multiple layers
1456
08-14-2017 06:09 AM
chrisweaves
Hello, I'm struggling a little here.
I'm trying obtain the list of features from mixed feature layers and display all the results in a ESRI popup widget (with carosel) similar to how this map identify works: Edit fiddle - JSFiddle
The example above is using an early version of the JS API so trying to figure out the new API equivalent is proving a bit tricky.  Any ideas?  Thank you very much.
Tags (1)
RobertScheitlin__GISP
Chris,
   What do you have so far? Using the latest release all you do is use the map.infoWindow.setFeatures([your array of features]);
KenBuja
MVP Esteemed Contributor
I'm working on a version of this for 4.x, but I'm not quite there yet. I'm using this example as a starting point.
