populate a combobox in jsviewer widget
1688
05-10-2013 12:38 AM
khadijaahal_el_fadl
I'm woriking with jsviewer and JSAPI v:2.8. in one of my widgets I have a combobox which I want to be populated once the widget is opened .It should be populated with a field values coming from a layer in mapservice. I have already the code to populate the combobox,I found it here:http://blogs.esri.com/esri/arcgis/2009/10/07/using-javascript-to-populate-a-combobox-with-unique-val... , but I can't use it correctly .I think the problem is in the way the function that populate the combobox is called(in startup
function ) or the widget can't access to the config data. pleaze if you have any idea ,I will be grateful.
VinayBansal
Try this.
[HTML]<select name="selectFilter" id="mySelectControl" dojotype="dijit.form.Select">
  </select>[/HTML]
var selectControl= dijit.byId("mySelectControl");
        if (this.fieldValues!= null && this.fieldValues.length > 0) {
            selectControl.addOption({ disabled: false, label: "- Values-", selected: true, value: "- Values-" });
            for (icnt = 0; icnt < this.fieldValues.length; icnt++) {
                        { disabled: false,
                            label: this.fieldValues[icnt],
                            selected: false,
                            value: this.fieldValues[icnt]
khadijaahal_el_fadl
Try this.
  </select>[/HTML]
                        { disabled: false,
                            selected: false,
thank you for replying ,
for the code you posted it seems that you use the field values stocked in json file,however, I want to populate the combobox
dynamically  from my layer.this is my js code ,I want just to know , if I missed something so that is doesn't work .thanx again:)
 dojo.provide("com.esri.solutions.jsviewer.widgets.DemoWidget");
dojo.require("com.esri.solutions.jsviewer._BaseWidget");
dojo.require("com.esri.solutions.jsviewer._MapGraphicsMaintainer");
dojo.require("dojo.i18n");
dojo.requireLocalization("com.esri.solutions.jsviewer.widgets", "DemoWidgetStrings");
dojo.require("dijit.form.Button");
dojo.require("dijit.form.ComboBox");
dojo.require("esri.tasks.query");
dojo.declare(
"com.esri.solutions.jsviewer.widgets.DemoWidget",
[com.esri.solutions.jsviewer._BaseWidget, com.esri.solutions.jsviewer._MapGraphicsMaintainer],
url: "",
fields:"",
query:"",
zoomScale:""
_module: "com.esri.solutions.jsviewer.widgets",
templatePath: dojo.moduleUrl("com.esri.solutions.jsviewer.widgets", "templates/DemoWidget.html"),
i18nStrings: null,
postMixInProperties: function() {
this.inherited(arguments);
if (this.configData) {
var L=this.configData.demo;
this.url = L.layer;
this.fields=L.fields;
this.query=L.query;
this.zoomScale = L.zoomScale;
this.i18nStrings = dojo.i18n.getLocalization( this._module, "DemoWidgetStrings");
postCreate: function(){
dojo.parser.parse(this.domNode);
startup: function() {
try {
if (this._initialized) { return; }
this.getAllNamedChildDijits();
this.init();
this.connects.push( dojo.connect(this.widgets.btnRecenter, "onClick", this, "onRecenter"));
this._initialized = true;
catch (err) {
console.error("DemoWidget::startup", err);
this.init();
onRecenter: function() {
var p = new esri.geometry.Point(-118.24799,33.975004);
this.map.centerAt(p);
init: function()
//Query task to populate dropdown list with country names*/
try {
if (this.url) {
this.setMessage(this.i18nStrings.msgLoad, true);
this.clearResults();
var url=this.url;
stateQueryTask = new esri.tasks.QueryTask(url);
stateQuery = new esri.tasks.Query();
stateQuery.returnGeometry = false;
stateQuery.outFields = this.fields;
stateQuery.where = this.query;
stateQueryTask.execute(stateQuery,updateStateDD)
catch (err) {
console.error("DemoWidget::init", err);
updateStateDD: function(results)
try{
var stateNames = new Array();
var selectObj = document.getElementById("countrySearch");
selectObj.options.length = 0;
var optObj = new Option("Choose a country");
selectObj.options[selectObj.options.length]=optObj;
for (var i=0, len=results.features.length; i<len; i++) {
var featureAttributes = results.features.attributes;
for (attribute in featureAttributes) {
var index = stateNames.indexOf(featureAttributes.country);
if(index == -1)
stateNames.push(featureAttributes.country)
catch (err) {
console.error("DemoWidget::updateStateDD", err);
VinayBansal
Are you getting the results in updateStateDD function?.And in result attributes are you getting the single field only.?
khadijaahal_el_fadl
Yeah, indeed, it work perfectely when it is in html file ( here is the example:http://serverapps.esri.com/javascript_examples/PopulateDropdownList.html) but doesn't with my widget .thank you for help 🙂
